Yes: There is connectors 2 wire if one gets frayed when you turn that direction the horn actually shorts causing it to blow. Back in the sixties when this happened. Put knees behind wheel and hit nut (not yourself
) those big old car wheels would pop right off. Ben
Nowdays I have wheel puller kits.
popcorn The Truth is Out There (It was a common problem back in the 50's & 60' funny until it happens to you turn honk turn honk jeesh)
