8 members (Hotrod Lincoln, Charles in CA, Gdads51, Cletus1950, J Lucas, dt235sd, 1955 1 Series, 1 invisible),
82
Mod | | | Forums66 Topics128,079 Posts1,056,300 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#90052 11/25/2004 4:42 AM | Joined: May 2004 Posts: 36 Apprentice | | Apprentice Joined: May 2004 Posts: 36 | My horn started blowing when I turn hard right. Guess wire in column needs more slack, LOL.
Mark | | |
#90053 11/25/2004 11:46 AM | Joined: Sep 2004 Posts: 235 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 235 | Makes every one look at the nice stove bolt coming around the corner | | |
#90054 11/25/2004 4:23 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Might get someones fist in your face. What year truck?  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#90055 11/25/2004 9:01 PM | Joined: May 2004 Posts: 36 Apprentice | | Apprentice Joined: May 2004 Posts: 36 | | | |
#90056 11/25/2004 9:24 PM | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Short in wire been ther done that. popcorn The Truth is Out There (Old chevy car whenever I turned left.) | | |
#90057 11/25/2004 9:31 PM | Joined: Jun 2004 Posts: 336 Member | | Member Joined: Jun 2004 Posts: 336 | Pop: did you have to pull the wheel to fix it? I expect that's what's required here.
Gord 1954 1/2 ton 235 4 speed
#90058 11/25/2004 11:41 PM | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Yes: There is connectors 2 wire if one gets frayed when you turn that direction the horn actually shorts causing it to blow. Back in the sixties when this happened. Put knees behind wheel and hit nut (not yourself  ) those big old car wheels would pop right off. Ben Nowdays I have wheel puller kits. popcorn The Truth is Out There (It was a common problem back in the 50's & 60' funny until it happens to you turn honk turn honk jeesh) | | |
#90059 11/26/2004 2:53 PM | Joined: May 2004 Posts: 36 Apprentice | | Apprentice Joined: May 2004 Posts: 36 | I figured I'd hafta pull the wheel, but do I hafta pull the steering column to rewire? Can't I just replace a fuse or somethin? LOL.
Mark | | |
#90060 11/26/2004 6:46 PM | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Guys: You have to remember when I did this I was in my late teens!!!! The old memory isn't very good. Thinking, i just cleaned the wire end up and reinstall screw. Didn't have to run any new wire. popcorn The Truth is Out There (almost 55 and I burned, killed, demolished to many brain cells)Ben | | |
#90061 11/27/2004 2:18 PM | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | Depends on function vs appearance. you can disconnect the horn wires in steering colum and add a dash mount horn button . doesn't look as good but its functional. seen it done on many work trucks. You don't have to remove steering wheel or column this way. | | |
