1 members (Steelonsteel), 94 guests, and 2 robots.
Topics128,090
Posts1,056,378
Members48,442
#90052 11/25/2004 4:42 AM
Apprentice
Apprentice
My horn started blowing when I turn hard right. Guess wire in column needs more slack, LOL.
Mark
Makes every one look at the nice stove bolt coming around the corner
Riding in the Passing Lane
Might get someones fist in your face.
What year truck? smile
1972 Chevy c10 Cheyenne Super
Apprentice
Apprentice
1940 1/2 ton
Short in wire been ther done that. popcorn The Truth is Out There (Old chevy car whenever I turned left.)
Pop: did you have to pull the wheel to fix it? I expect that's what's required here.
Gord
1954 1/2 ton 235 4 speed
Yes: There is connectors 2 wire if one gets frayed when you turn that direction the horn actually shorts causing it to blow. Back in the sixties when this happened. Put knees behind wheel and hit nut (not yourself grin ) those big old car wheels would pop right off. Ben
Nowdays I have wheel puller kits.
popcorn The Truth is Out There (It was a common problem back in the 50's & 60' funny until it happens to you turn honk turn honk jeesh)
Apprentice
Apprentice
I figured I'd hafta pull the wheel, but do I hafta pull the steering column to rewire? Can't I just replace a fuse or somethin? LOL.
Mark
Guys: You have to remember when I did this I was in my late teens!!!! The old memory isn't very good. Thinking, i just cleaned the wire end up and reinstall screw. Didn't have to run any new wire. popcorn The Truth is Out There (almost 55 and I burned, killed, demolished to many brain cells)Ben
Depends on function vs appearance. you can disconnect the horn wires in steering colum and add a dash mount horn button . doesn't look as good but its functional. seen it done on many work trucks. You don't have to remove steering wheel or column this way.
