6 members (78buckshot, Gdads51, HandyAndy, Opelika Tom, klhansen, 1 invisible), 128 guests, and 3 robots.
Topics128,062
Posts1,055,847
Members48,428
#900080 11/29/2012 11:37 AM
My newer (1994) Chevy pickup has 151,000 miles on it. The rear end clunks when I stop and go again. There seems to be a lot of backlash so I assume this is the problem. It's driving me nuts, and my neighbor tells me not to tighten up the clearance because it will just wear out faster.
I was thinking of R&R the whole rear end bearings because I am driving this truck daily.
What do you guys think? R&R it? Tighten up the clearance? Different rear end or gears?
Builder #900085 11/29/2012 12:05 PM
I'd pull the cover and take a look. I'd also take the driveshaft out and check u-joints close. My Silverado has 292K on it and I was getting a clunk and thought rear end, ended up being a u-joint that was tight.
Builder #900088 11/29/2012 12:18 PM
It has new ujoints. I changed the rear end lube, all looked good (what I could see). That is when I questioned the end play because it seemed quite loose.
Riding in the Passing Lane
If there is no whining noises it probably has worn spider gears.
Like Don says pull the cover & see what you have. You can buy the whole set in a kit. It comes withthe shaft, side gears, & pinion gears. If it uses trust washers they will be inclded.
1972 Chevy c10 Cheyenne Super
