| | | Forums66 Topics128,049 Posts1,055,682 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | My newer (1994) Chevy pickup has 151,000 miles on it. The rear end clunks when I stop and go again. There seems to be a lot of backlash so I assume this is the problem. It's driving me nuts, and my neighbor tells me not to tighten up the clearance because it will just wear out faster. I was thinking of R&R the whole rear end bearings because I am driving this truck daily.
What do you guys think? R&R it? Tighten up the clearance? Different rear end or gears? | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I'd pull the cover and take a look. I'd also take the driveshaft out and check u-joints close. My Silverado has 292K on it and I was getting a clunk and thought rear end, ended up being a u-joint that was tight. | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | It has new ujoints. I changed the rear end lube, all looked good (what I could see). That is when I questioned the end play because it seemed quite loose. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If there is no whining noises it probably has worn spider gears. Like Don says pull the cover & see what you have. You can buy the whole set in a kit. It comes withthe shaft, side gears, & pinion gears. If it uses trust washers they will be inclded. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
