7 members (Uncles51, 78buckshot, Peggy M, Youngin' Tut 59, Cletus1950, delwrench, 1 invisible), 105 guests, and 2 robots.
Topics128,174
Posts1,057,048
Members48,458
#890611 10/19/2012 7:51 PM
Anyone got advice on the best way to convert a 62 C10 to power steering? I'm running a 235. I see some steering box bracket adapters. Often these set ups are for '64 and up.
I tried searching previous postings and didn't find much.
Thanks!!
Glen
There are some great tech articles here. Not promoting their product, just good reading material.
http://www.classicperform.com/tech_articles/Old-School-Power/PowerSteeringProjectOldSchool.htm
http://www.classicperform.com/power6066.htm
Jon S
Las Vegas NV
1966 GMC Suburban 305V6
Psalm 66 "Make a joyful noise"
http://i12.photobucket.com/albums/a205/gvdobler/0205011645b.jpg
Thanks Jon. This is helpful!!
Glen
Hi Glen,
One of our members, 4-5-6 Chevy Trucks, makes and sells a kit to do just that! Look him up and give him a shout!
Best wishes,
Les
Thanks for the kudos, Roadmarks.
When converting the '60, '61 & '62 Chevy truck, factory six cylinder (235 cid) motors,to power steering, the challenge is locating the correct power steering pump mounting brackets. The 230, 250 & 292 six cylinder power steering pump mounting brackets are not the same and are not interchangeable, for use on the 235 sixes. That will be the challenging assembly to locate.
Our kit is specific for the '63-'66 Chevy truck 230, 250 & 292 six cylinders.
Hmmm... Maybe I can fabricate the brackets. What is now scaring me is finding a 2-groove harmonic balancer for a 235 for under 400 bucks!
I bought 235 PS bracket kit from member Chris Drum: [email protected] and cell is 570-233-1172. Regrettably, I've been distracted by two other projects and haven't installed yet, but the instructions and pix are clear.
Thanks Nomad.
Howdy Glen, I also purchased the pump mount from Chris for my 55, I now have a 62 like yours and will need another mount. They are nice parts for the 235, 261 engines.
1 1955 Chev one ton. 261 engine
3 1962 Chev c-10 261 engine
4 1966 Plymouth VIP 5.7 GenIII Hemi
5 1966 Imperial Crown Coupe 440 engine
I
I Offline
I've lucked into a '73 steering box with hoses and pump. I would like to use the mount from Chris for my 58-59 235. I've ordered the CPP install kit. With Chris' mount will the pump like up with the existing pulley's so that I can just get a longer belt? Are there any rpm issues betweens the various pulleys? Thanks!
'62 Chevy C10 Short Bed Step Side, 235 Six with Offy intake, 2 carter/weber 2bbls and Fenton headers. B-W T5 5 speed trans, with stock rear end.
I
I Offline
_________________________
