8 members (Bill Trotter, Hotrod Lincoln, JoergK., Cosmo, klhansen, Stovebolt48, 1955 1 Series, Bill Hanlon), 117 guests, and 1 robot.
Topics128,195
Posts1,057,373
Members48,469
The threads, both female and male are worn, so when I start the 52 half-ton, I have to be careful of the male post falling out onto the floor. If I want to be able to take it on and off while restoration in progress, how do I fix it, to save the old nicely worn-looking original parts. (previous fix, many years ago was to wrap threads with some steel wool and screw it back on.)
thanks, Brad
1952 Chevy 1/2-ton
"Me and Ol Blue/True Blue Both Born in '52"
Follow this fun story in the DITY
helicoil?
Agreed! Simple to do and permanent. Or try to find a used assembly.
Ed
Thank you, for suggestion. I will inspect male side to see if there is enough thread left to screw into helicoil fix?
Brad
1952 Chevy 1/2-ton
I suppose you could add weld material to the (male) foot pedal post and use a die to rethread to proper size (or a size that will work).
