| | | Forums66 Topics128,195 Posts1,057,376 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 55 'Bolter | | 'Bolter Joined: May 2007 Posts: 55 | The threads, both female and male are worn, so when I start the 52 half-ton, I have to be careful of the male post falling out onto the floor. If I want to be able to take it on and off while restoration in progress, how do I fix it, to save the old nicely worn-looking original parts. (previous fix, many years ago was to wrap threads with some steel wool and screw it back on.) thanks, Brad | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Agreed! Simple to do and permanent. Or try to find a used assembly.
Ed
| | | | | Joined: May 2007 Posts: 55 'Bolter | | 'Bolter Joined: May 2007 Posts: 55 | Thank you, for suggestion. I will inspect male side to see if there is enough thread left to screw into helicoil fix? Brad | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | I suppose you could add weld material to the (male) foot pedal post and use a die to rethread to proper size (or a size that will work). | | |
