2 members (RLB, baldeagle),
43
Mod | | | Forums66 Topics128,003 Posts1,055,244 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#89909 01/06/2005 12:01 AM | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | I just bought a "new" (taken from another old truck) instrument cluster for my 62. The speedometer works but the odometer doesn't. In order to fix the odometer I need to take the needle off of it's thin shaft so that I can get to the screws holding the unit together. I broke the shaft on my old speedometer trying to pry the needle off and I don't want to do it again.
How do I get the speedometer needle off of that thin shaft without breaking the shaft?
delete my account and pictures
#89910 01/06/2005 5:01 AM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I'm not sure but have you tried soaking the speedo w/sewing machine or 3 in 1 oil? All of them I have messed with just needed oiling to start working again. Brian | | |
#89911 01/07/2005 4:26 PM | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | 64fleetside: No, I haven't tried oiling it because I can't see where to apply the oil. It doesn't look like it's rubbing anywhere. Do you just drench it?
#89912 01/10/2005 3:59 AM | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | 64fleetside: I removed my speedo and got the odometer working. The numbers were locked up. I hope that it didn't cause damage to the worm gears which drive them...
Anyway, My old speedometer went nuts. It started making a horrible noise. I kept driving hoping that it would stop but instead it got worse. I was on my way to San Antonio to pick up my new Superglide. I didn't feel like stopping. It finally pegged the needle until it broke off but that didn't stop the god-awful noise. I finally pulled over and disconnected it. So that unit was shot. The "new" one has a similar problem though not as bad. I oiled it pretty well and will test it tomorrow.
#89913 01/11/2005 2:21 AM | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | Well, the odometer works now but the speedo pulses badly. It stopped squeaking though. lol....
#89914 01/11/2005 10:34 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Have you greased the cable?  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#89915 01/11/2005 11:02 PM | Joined: Jun 2004 Posts: 336 Member | | Member Joined: Jun 2004 Posts: 336 | Wrenchbender, on my "new" truck (1980), I was able to easily pull the speedo cable out of the sheath and replace it with a new one. The cable was unravelling causing an unsteady reading like Tab describes. On my old truck (1954), the cable won't come out of the sheath for cleaning and greasing; is is supposed to come out?
Gord 1954 1/2 ton 235 4 speed
#89916 01/12/2005 12:36 AM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Yes! It,s the same setup except for the connector at the speedo. It should pull out from the top. try some wd40 type & pull with needle nose plyers. You may have to replace the whole cable & housing.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#89917 01/12/2005 3:13 AM | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | Excellent idea. Why didn't I think of that?
#89918 01/12/2005 5:04 AM | Joined: Jun 2004 Posts: 336 Member | | Member Joined: Jun 2004 Posts: 336 | Thanks Wrenchbender! It came right out this time. I tried to pull it out a couple of months ago; it didn't budge and I didn't want to force it. So I dribbled lots of light oil on the cable and hung it vertically. Forgot about it until I saw this post. The cable looks undamaged - just a bit sticky.
What type of lube would you recommend?
#89919 01/12/2005 11:51 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Lube it with chassis grease. Tab are you being sarcastic?  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#89920 01/13/2005 6:26 AM | Joined: Jun 2004 Posts: 336 Member | | Member Joined: Jun 2004 Posts: 336 | Thanks. I have lots of chassis grease!
