Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (KCMongo, baldeagle), 33 guests, and 1 robot.
Topics128,005
Posts1,055,254
Members48,418
#89909 01/06/2005 12:01 AM
Tab
Offline
I just bought a "new" (taken from another old truck) instrument cluster for my 62. The speedometer works but the odometer doesn't. In order to fix the odometer I need to take the needle off of it's thin shaft so that I can get to the screws holding the unit together. I broke the shaft on my old speedometer trying to pry the needle off and I don't want to do it again.
How do I get the speedometer needle off of that thin shaft without breaking the shaft?
delete my account and pictures
#89910 01/06/2005 5:01 AM
I'm not sure but have you tried soaking the speedo w/sewing machine or 3 in 1 oil? All of them I have messed with just needed oiling to start working again. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#89911 01/07/2005 4:26 PM
Tab
Offline
64fleetside: No, I haven't tried oiling it because I can't see where to apply the oil. It doesn't look like it's rubbing anywhere. Do you just drench it?
#89912 01/10/2005 3:59 AM
Tab
Offline
64fleetside:
I removed my speedo and got the odometer working. The numbers were locked up. I hope that it didn't cause damage to the worm gears which drive them...
Anyway, My old speedometer went nuts. It started making a horrible noise. I kept driving hoping that it would stop but instead it got worse. I was on my way to San Antonio to pick up my new Superglide. I didn't feel like stopping. It finally pegged the needle until it broke off but that didn't stop the god-awful noise. I finally pulled over and disconnected it. So that unit was shot. The "new" one has a similar problem though not as bad. I oiled it pretty well and will test it tomorrow.
#89913 01/11/2005 2:21 AM
Tab
Offline
Well, the odometer works now but the speedo pulses badly. It stopped squeaking though. lol....
#89914 01/11/2005 10:34 PM
Riding in the Passing Lane
Have you greased the cable? smile
1972 Chevy c10 Cheyenne Super
#89915 01/11/2005 11:02 PM
Wrenchbender, on my "new" truck (1980), I was able to easily pull the speedo cable out of the sheath and replace it with a new one. The cable was unravelling causing an unsteady reading like Tab describes. On my old truck (1954), the cable won't come out of the sheath for cleaning and greasing; is is supposed to come out?
Gord
1954 1/2 ton 235 4 speed
#89916 01/12/2005 12:36 AM
Yes! It,s the same setup except for the connector at the speedo. It should pull out from the top. try some wd40 type & pull with needle nose plyers. You may have to replace the whole cable & housing. smile
#89917 01/12/2005 3:13 AM
Tab
Offline
Excellent idea. Why didn't I think of that?
#89918 01/12/2005 5:04 AM
Thanks Wrenchbender! It came right out this time. I tried to pull it out a couple of months ago; it didn't budge and I didn't want to force it. So I dribbled lots of light oil on the cable and hung it vertically. Forgot about it until I saw this post. The cable looks undamaged - just a bit sticky.
What type of lube would you recommend?
Gord
#89919 01/12/2005 11:51 PM
Lube it with chassis grease.
Tab are you being sarcastic?
smile
#89920 01/13/2005 6:26 AM
Thanks. I have lots of chassis grease!
Gord
