1 members (1 invisible), 105 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#898820 11/23/2012 9:11 PM
On our 55.2 3600 truck, there was a PTO on the side of the 4 speed top loader trans. I assume the PTO was installed by the fire company that owned it before me, to operate the water pump in the bed.
Anyhow, I do not need the PTO and wanted extra room under the body and also wanted to clean up the driveline area a little bit. I have the PTO off the trans and I neeed a block off plate. I was gonna make one out of flat stock, this would work eh? I would use gasket paper to seal it along with some good silicone gasket sealant. Is there anything else I need to do before I close the access hole up? I am gonna post the PTO for sale in Parts For Sale.
1952 GMC model 473 dump truck
1951 Chevy 1500 stepside
The shortest bolts you can buy...they need not go in and interfere with the internals,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
any HD Truck shop should have the parts cheap. I recommend copper washers to help seal the bolts.
1953 Chevy 3100
261 and SM420
53Chevy 3100
1953 Mack Firetruck
1972 Porsche 911
1986 Honda Goldwing
