0 members (),
137
Mod | | | Forums66 Topics128,211 Posts1,057,475 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2012 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2012 Posts: 25 |
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Although there were a few 1947 "First" series I think it is definitley a 41-46 year model. I'm sure someone will come along that can definitely say for sure. Judging from the inside of the drivers door I think it may be a '41....just my opinion. This style truck is known as Art Deco style. '47 was the Advance Design better known as the AD style.
Hang tight. Someone will be along shortly for sure. | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | Parking lights are gone, so can't tell there, look at the rear window, if it's held in with a pot metal casting it's 41, if held in with a rubber moulding it's 42 or newer. 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Have a look on the cowl and firewall for a metal id tag.
| | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | It looks like a 46 1/2 ton to me. The rear window appears to be held in with a rubber gasket, which would make newer than a 41. Also the 3/4 ton would have three stake pockets in the bed. Someone may come along and prove me wrong but that's the way it looks to me. George | | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | Also looks 1/2 ton to me also. In pic #7,The rear drivers fender looks close to the cab like a short bed would have.
| | | | | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | Looks like a 42-46 1/2 ton to me. Look at the passenger door for the lock, should be in the Handle if it is in the door it is at very least a 42-46 door. Rear window trim ring inside 13 Screws Bed has only 2 stake pokets so it's a 1/2 ton.
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
| | | | | Joined: Jul 2012 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2012 Posts: 25 | Thank you everyone for the replies, Ill def post pics once I get it home on the trailer. I figured I couldnt pass it up as it was a great deal, and I never know what I may need for my Arizona find im working on,, Thanks again everyone! Bill | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Can you get some photos of the drive line, rear axle spring mounts, inside of the rear window, side of the bed and the outside of the passenger door.
These should help with the capicity and year. | | | | | Joined: Nov 2000 Posts: 1,974 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,974 | That'll buff out real good.  It's got potential. I suggest you get the title straightened out first. Is there any significance to 1 wiper above the w/s rather than in the cowl? I don't know very much about Art Deco trucks.
Professional Novice
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | All Art Deco's had the wipers above the windshield. My 46 had 2, not sure if that's common or not. | | | | | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | They put the wiper above the window to allow the windshield to swing out at the bottom.
