| | | Forums66 Topics128,181 Posts1,057,180 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 97 Shop Shark | | Shop Shark Joined: May 2009 Posts: 97 | I'm sure there are people on here that has raked their trucks but can't seem to find any information on the degree of rake. Is there anybody on here that has done this? If so what degree of rake did you go and also can you send me a link to your pictures so I may see if I even want to do this. I am thinking about dropping the overall ride height about an inch from stock. Thanks in advance. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | That'll be hard on the paint, try a broom instead.... | | | | | Joined: May 2009 Posts: 97 Shop Shark | | Shop Shark Joined: May 2009 Posts: 97 | haha nice. By the looks of things I might not be raking or sweeping (LOL)it at all as not getting any replies.
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | The amount of rake depends on what you like personally. There is no set formula or degree, and it depends on the way the vehicle looks too.
I usually like 1/2" to 1" difference in running board height from front to back, for a visible rake. That depends greatly on what you like though. | | | | | Joined: May 2009 Posts: 97 Shop Shark | | Shop Shark Joined: May 2009 Posts: 97 | Did you do this on your 46? | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | mine is about 2" lower on the front,but much lower that stock height. | | | | | Joined: May 2009 Posts: 97 Shop Shark | | Shop Shark Joined: May 2009 Posts: 97 | BC52 I like the way that looks. What is your front and rear ride heights? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 |
| | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | BC52 I like the way that looks. What is your front and rear ride heights? The truck is on jack stands right now,but I think the front bumper is 7" from the ground.It was lower,but the bumper hit things.  | | | | | Joined: Mar 2011 Posts: 229 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 229 | i like very little rake maybe an inch if not level, but im just a flunky from north dakota though. later MO
MO's 1951 chevy 3100 resto mod project
| | | | | Joined: May 2009 Posts: 97 Shop Shark | | Shop Shark Joined: May 2009 Posts: 97 | Achipmunk,
I like the rake you have on there, just enough to notice. Should have seen me trying to visualize it with a forward rake. it was a funny site. There's a ole willy truck, I think it's a willy, that I've seen a few times but mostly at the car show they have at a drag strip around here. He has his rake like 4 or 5 if not more inches to the back like that. To me it just doesn't look right but then again I don't know anything about drag racing so he might have it like that for the track?
| | | | | Joined: May 2009 Posts: 97 Shop Shark | | Shop Shark Joined: May 2009 Posts: 97 | BC52,
When I was looking at mine this past weekend I was measuring about 8 inches from the ground. So if I do a small rake I might start the front at 7 or 7 1/2 and come up to 8 or 8 1/2 in the rear. | | | | | Joined: May 2009 Posts: 97 Shop Shark | | Shop Shark Joined: May 2009 Posts: 97 | Mo,
I don't like a ton of rake so I understand where your coming from. I'm just wanting a small amount to show a small muscle car look but definitely not going to be a drastic rake. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Did you do this on your 46? Yes, my truck has about an inch of rake front to rear. However, my front filler pan under the grille is about 6 to 6.5" off the ground, so that makes it look way different too. | | | | | Joined: May 2009 Posts: 97 Shop Shark | | Shop Shark Joined: May 2009 Posts: 97 | Nice. Thanks everybody for their input. | | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | Mine is about about 2" lower and (much lower than stock) also.. Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | | Joined: May 2009 Posts: 97 Shop Shark | | Shop Shark Joined: May 2009 Posts: 97 | 1bad51,
Man I love the way your truck sits. You by any chance have the frame measurements when it was bare frame? Reason I'm asking is that I know after the frame settles and the weight of everything on the frame it'll drop some but I'm not sure by how much. I'll be able to make some changes to it as I'm going with air bags.
