2 members (baldeagle, 1 invisible),
90
Mod | | | Forums66 Topics128,018 Posts1,055,340 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 33 | hello guys I have a 1952 one ton panel and wish to remove the body and put it on a 1997-99 Gmc xl frame. has anyone any ideas on this or which chassis would be better for a 173 " wheel base
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | You may want to ask this question in the paint and body forum. I know one bolter, and I'm sure others, have made the switch. Weeds, a bolter here, put a surburban body on what I remember as being a GMC chassis. I'm sure others will chip in here. Godo luck. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I have seen some S-10's that look OK.
| | | | | Joined: Feb 2005 Posts: 13 New Guy | | New Guy Joined: Feb 2005 Posts: 13 | track on fullsize frame is too wide Tires will stick out | | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | Do you mean 137" wheelbase? There is a gentleman doing a similar build in the DITY sub forum in the Welcome Center here. Look for 4x4 build near the top.
I wonder if you could stretch a Chevy Trailblazer Extended with the 129" wheelbase? They also came with a 5.3 V8, might be a little too new yet for a used one. | | | | | Joined: Nov 2005 Posts: 323 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 323 | I am looking at using an '88 GMC K2500 standard cab longbed frame for my '47 1ton panel. I plan on moving the rear leaf springs back a few inches. I currently have a rear axle from an '88 sub under the panel and the tires do not stick out. wish me luck! | | |
