5 members (78buckshot, baldeagle, ShopRag, J Lucas, Wally / Montana), 73 guests, and 6 robots.
Topics128,020
Posts1,055,345
Members48,420
#896091 11/11/2012 8:39 PM
hello guys I have a 1952 one ton panel and wish to remove the body and put it on a 1997-99 Gmc xl
frame. has anyone any ideas on this or which chassis would be better for a 173 " wheel base
archiemark #896126 11/11/2012 10:22 PM
You may want to ask this question in the paint and body forum. I know one bolter, and I'm sure others, have made the switch. Weeds, a bolter here, put a surburban body on what I remember as being a GMC chassis.
I'm sure others will chip in here. Godo luck.
Achipmunk #896216 11/12/2012 11:55 AM
Crusing in the Passing Lane
I have seen some S-10's that look OK.
track on fullsize frame is too wide Tires will stick out
Do you mean 137" wheelbase? There is a gentleman doing a similar build in the DITY sub forum in the Welcome Center here. Look for 4x4 build near the top.
I wonder if you could stretch a Chevy Trailblazer Extended with the 129" wheelbase? They also came with a 5.3 V8, might be a little too new yet for a used one.
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
1924 Ford Model T Fordor
I am looking at using an '88 GMC K2500 standard cab longbed frame for my '47 1ton panel. I plan on moving the rear leaf springs back a few inches. I currently have a rear axle from an '88 sub under the panel and the tires do not stick out. wish me luck!
1947.2 Chevy Panel Truck 1-ton
In Project Journals
In the DITY Gallery
1955.2 Chevy Suburban
1955.2 Chevy 6700 Bus/RV
Moderated by  Dusty53
