9 members (JoergK., klhansen, Hotrod Lincoln, Stovebolt48, 1955 1 Series, Bill Hanlon, fonz8261, latroca52, 1 invisible),
104
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,195 Posts1,057,373 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 54 | Hi guys - have mounted the bed back on my truck. I have a new wood and bolt kit, but I was wondering if anyone had a pic of their bed with the correct place for the cross sills. I think i know where the front and back bars go, from the pictures i took on disassembly, but I'm not sure where the middle one goes as there doesn't seem to be any holes in the frame for it. I looked on mar k but there wasn't any diagrams that helped. Thanks, Matt | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Testing my memory here....as I recall, that sill piece just rests on the curve of the frame. Location is determined by underside of bed boards ? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ..Bruce is right. There is a sill on each side of the frame where it kicks up. I'll bet if you slide the sill along the chassis with the block underneath it you'll get to a point where you may find the hole in the chassis. Curious if you find the holes. Maybe this will help. This is my 37 and the one just before the rear. No guarantee that this is 100% correct due to condition of my truck when I started on it but I "believe" it is correct. http://i140.photobucket.com/albums/r19/LutherParris/Nexttorear.jpg
| | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | | | | | | Joined: Sep 2011 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 54 | Hey guys - thanks for the info. I'll have to test out the position a bit more when i get back out there. | | |
