4 members (Napco Man, WICruiser, Jon G, stlcardinalsguy), 410 guests, and 5 robots.
Topics128,163
Posts1,057,044
Members48,463
I am trying to take the tank out of my 53 I removed the seat, took the straps off and I took the filler neck hardware off. I tried to wiggle the tank a little to make sure I had it all and the tank is not budging at all. Is there something else I am missing?
1953 Chevy 3600
fuel line and drain?
Is is stuck with 59 years of spilled coke, coffee, and who knows what? It sits on 4 asphaltic pads wiggle it back and forth it should come?
The only thing I haven't unhooked yet was that fuel line under the truck I am gonna do that next.
1953 Chevy 3600
Got it.
Brad you were exactly right!
1953 Chevy 3600
When you put it back if you can't find pads get some used mountain bike tires and cut them to fit. Work perfectly.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
I'll keep that in mind
1953 Chevy 3600
Using old mountain bike tires? What a great idea, since I'm in the bicycle business.
Craig
That's a great idea even if you are not in the bicycle business! It should ba added to the TECH TIPS section.
David Gilmore
Stovebolt Pictures
Paint progress
____________________________
1950 Chevy 3600
I'm about to put the gas tank back in my 3600 and can't remember how it was assembled. I'm going to buy straps but they appear like there is only one attachment place at the end of the tank bracket. From what I've read here, it seems like the other side sits on the inside rail of the frame. Is this correct? Classic Chevy parts https://www.classicparts.com/basket.asp
Another gas tank strap related part that is available but,. I can't tell how it might be mounted.
https://www.classicdiscountparts.com/products.php?product=47%25252d54-Chevy-Truck-Gas-Tank-Brackets-with-Straps-(WTP)&gclid=Cj0KCQjwwb3rBRDrARIsALR3XeaZyhDAzCis_n9bQ15zTzlzta13uFVOVlXyY1oOTLl6GQFbjXJMfhQaApsVEALw_wcB
Your url posted for gas tank brackets is for mounting the tank inside the cab behind the seat. It welds to the floor behind the seat riser. The longer strap goes around the back of the tank and bolts to the shorter strap.
24601
24601
Mountain bike tire pieces aren't too thick? I used some glass setting tape (strips of rubber for setting the window glass back inside the outer frames on the early AD door glass) I had left over and it worked great.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
KlHansen, Thanks for clearing that up for me. Luckily mine is a stock inside the frame rails installation. Do you know how the tank is mounted this way? The mounting brackets only have one attachment hole and the straps appear to have only one point of attachment so, either the tank hangs just from these two holes (two mounting brackets) or also rest on the frame rails. I got this impression from the talk about using bike tube rubber as a cushion. I could find out by buying the straps and checking the fit but, I'm a little hesitant to layout 90 bucks for something I can easily fab. I was just wanting to get a clear understanding about how the stock tank was held in place.
Joel
The Factory Assembly Manual shows brackets attached to the frame rail extending over the tank with the strap bolted to the bottom of the frame rail, extending under the tank and bolting with the threaded end to the inboard end of the brackets. It shows anti-squeak material glued to the inboard and outboard parts of the bracket where it contacts the tank. It's Section 8, Sheet 1.01 if you have the FAM.
I'm looking at sheet 1.01 3600 model very near to the front of the book but, don't see that good of detail. There must be another I'm not finding.
Go back to Section 8, Sheet 1.01. Sounds like you're at Section 0, Sheet 1.01, which is the "index" page.
Kevin,
Now I see how to use the assembly manual and, I can see how easy it will be to make my own straps.
Thanks for your help.
