1 members (GMCJammer51), 122 guests, and 5 robots.
Topics128,266
Posts1,058,386
Members48,485
#893275 10/30/2012 2:35 PM
I have about 2 1/2 feet of windlace that detached from the inside of the truck. So I am looking for ideas to reattach the channel. I could plug weld or tach weld along the sides, but I am concerned about the windlace fitting well. So anyone have an alternative to welding it, or would the best approach be just to go ahead and weld it back in place. Also my welding skills aren't what they once were.
I have the sample problem and plan on pop riveting the channel back in place
Joe
1955 First Series 3100
Jimmie D #894075 11/02/2012 10:38 PM
The windlace is the track for the door windows I put mine in with some small stainless screws (1/2 x 4) so I could take it out if I needed to - which I have twice now.
1951 Chevy 3100 5-Window
"Howard"
More pix on Photobucket
Tack weld it back on about 2 inches apart. It needs to be solid when you start pulling the rubber windlace back in track.
Thanks for all the comments. I decided to use steel rivits. I put them 4 inches apart, and they seem to be very solid. After I get the finishing touches on the inner cowl panel, I will install the windlace and report back.
Moderated by  ndkid275, Phak1
