7 members (Otto Skorzeny, J Lucas, dt235sd, Cosmo, jeffreyguy, Charles in CA, LAROKE),
132
Mod | | | Forums66 Topics128,107 Posts1,056,221 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 124 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 124 | So I finally got my engine going but I CANNOT find the proper fitting anywhere locally to save my life to hook up the little oil pressure line to the engine. I got a 1/8" x 1/8" fitting and the inverted flare side is too big; so I guess I need 1/8 x 5/16 inverted flare? Where can I find the proper one online? Finding this stupid little fitting is driving me nuts at this point! I've looked at Lowes, True Value, other local hardware stores--NOTHING! | | | | | Joined: Feb 2004 Posts: 29,802 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,802 | Inverted flare? Most oil pressure lines use a 1/8" compression fitting/1/8" pipe male fitting to adapt the small plastic or copper line to the port in the block. There is also an oddball crimp-type fitting with a male thread that's a one-time use thing, but it requires a special adapter fitting to crimp the pointed end of the nut into the tubing on the first installation. After that, the nut stays attached to the oil line permanently. Jerry
| | | | | Joined: Jun 2011 Posts: 124 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 124 | Inverted flare? Most oil pressure lines use a 1/8" compression fitting/1/8" pipe male fitting to adapt the small plastic or copper line to the port in the block. There is also an oddball crimp-type fitting with a male thread that's a one-time use thing, but it requires a special adapter fitting to crimp the pointed end of the nut into the tubing on the first installation. After that, the nut stays attached to the oil line permanently. Jerry Thanks for the reply but now I'm really confused! LOL> | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The easiest way would be to get the 1/8-1/8 compression fittingb like HRL described & cut the line just above the swivel. It is available at any parts store & possibly hardware store. I could probably find the crimp type fitting he is refering to but it would take a few days for you to get it. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jun 2011 Posts: 124 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 124 | So they don't sell a simple fitting that will bolt into the engine and accept the stock oil pressure line? | | | | | Joined: Feb 2004 Posts: 29,802 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,802 | The fittings you need are on Ebay, but the PC Patrol will delete a link if I list one. Search Ebay Motors for "oil pressure line kit". The fitting you need is an adapter included in the "63-67 Corvette" oil line kit. It screws into a 1/8" pipe female thread and accepts the crimped-on nut that's currently on your oil line. If the nut on your line is bad, the kit contains two new ones, and a piece of 1/8" copper line. That adapter is a very scarce fitting, so don't lose it this time! Jerry
| | | | | Joined: Feb 2000 Posts: 5,216 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,216 | | | | | | Joined: Jun 2011 Posts: 124 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 124 | Thanks for the info guys. I will first see if I can get the fitting. If not I'm forced to buy the $20 kit from Wilcox Corvette.
Jerry, I normally wouldn't have lost the fitting but the truck was mine first back in 1996 then my dad's and there was a 15 year gap from the time the engine was pulled and rebuilt and this month when I finally installed it and fired it up after I finally convinced him to let me have it so I could get her running. There was pieces everywhere and I had to buy a few missing pieces including these lines. | | |
