2 members (BC59, Gray_Ghost), 154 guests, and 1 robot.
Topics128,079
Posts1,056,058
Members48,433
So I finally got my engine going but I CANNOT find the proper fitting anywhere locally to save my life to hook up the little oil pressure line to the engine. I got a 1/8" x 1/8" fitting and the inverted flare side is too big; so I guess I need 1/8 x 5/16 inverted flare? Where can I find the proper one online? Finding this stupid little fitting is driving me nuts at this point! I've looked at Lowes, True Value, other local hardware stores--NOTHING!
Inverted flare? Most oil pressure lines use a 1/8" compression fitting/1/8" pipe male fitting to adapt the small plastic or copper line to the port in the block. There is also an oddball crimp-type fitting with a male thread that's a one-time use thing, but it requires a special adapter fitting to crimp the pointed end of the nut into the tubing on the first installation. After that, the nut stays attached to the oil line permanently.
Thanks for the reply but now I'm really confused! LOL>
Riding in the Passing Lane
The easiest way would be to get the 1/8-1/8 compression fittingb like HRL described & cut the line just above the swivel. It is available at any parts store & possibly hardware store. I could probably find the crimp type fitting he is refering to but it would take a few days for you to get it.
George
1972 Chevy c10 Cheyenne Super
So they don't sell a simple fitting that will bolt into the engine and accept the stock oil pressure line?
The fittings you need are on Ebay, but the PC Patrol will delete a link if I list one. Search Ebay Motors for "oil pressure line kit". The fitting you need is an adapter included in the "63-67 Corvette" oil line kit. It screws into a 1/8" pipe female thread and accepts the crimped-on nut that's currently on your oil line. If the nut on your line is bad, the kit contains two new ones, and a piece of 1/8" copper line. That adapter is a very scarce fitting, so don't lose it this time!
Thanks for the info guys. I will first see if I can get the fitting. If not I'm forced to buy the $20 kit from Wilcox Corvette.
Jerry, I normally wouldn't have lost the fitting but the truck was mine first back in 1996 then my dad's and there was a 15 year gap from the time the engine was pulled and rebuilt and this month when I finally installed it and fired it up after I finally convinced him to let me have it so I could get her running. There was pieces everywhere and I had to buy a few missing pieces including these lines.
