7 members (Otto Skorzeny, 55shaker, joe apple, Gray_Ghost, Hush, 52Carl, JW51), 155 guests, and 2 robots.
Topics128,108
Posts1,056,238
Members48,437
#891635 10/24/2012 7:17 AM
kks
Offline
235 engine can someone give me a run down on how to change the oil in my 54 Chevy truck. Thanks
kks #891723 10/24/2012 1:35 PM
Warm engine up a little,put a oil catch pan under the oil pan, screw out the pan plug and oil will drain out. Open the valve cover oil fill cap too on the odd chance vacuum restricts draining. Have an oil filter? Change that too. Refill with fresh, correct weight and grade, and required number of quarts of oil.
Drew
kks #891739 10/24/2012 3:10 PM
Be sure to put the oil pan plug back in after you've finished draining before you add new oil... not that I've ever made that mistake... ok... once I did. dang
kks #891770 10/24/2012 5:15 PM
kks, here is the link to the online version of the 1954 Chevrolet Truck Shop Manual ...
While you are changing the oil here is the Lubbication Chart for all the other places you need to keep lubricated ...
It is a good investment to get a hard copy of the 1954 Chevrolet Truck Shop Manual and 1947-1954 Truck Factory Assembly Manual ...
Got any pics of your 54 ?
The Welcome Center is a good place to post pics and here the How to post photos on the Stovebolt site ...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
