2 members (Gray_Ghost, 1 invisible),
238
Mod | | | Forums66 Topics128,106 Posts1,056,213 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 8 New Guy | | New Guy Joined: Oct 2012 Posts: 8 | 235 engine can someone give me a run down on how to change the oil in my 54 Chevy truck. Thanks | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Warm engine up a little,put a oil catch pan under the oil pan, screw out the pan plug and oil will drain out. Open the valve cover oil fill cap too on the odd chance vacuum restricts draining. Have an oil filter? Change that too. Refill with fresh, correct weight and grade, and required number of quarts of oil.
Drew
| | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | Be sure to put the oil pan plug back in after you've finished draining before you add new oil... not that I've ever made that mistake... ok... once I did.  Jerry | | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | kks, here is the link to the online version of the 1954 Chevrolet Truck Shop Manual ... While you are changing the oil here is the Lubbication Chart for all the other places you need to keep lubricated ... It is a good investment to get a hard copy of the 1954 Chevrolet Truck Shop Manual and 1947-1954 Truck Factory Assembly Manual ... Got any pics of your 54 ? The Welcome Center is a good place to post pics and here the How to post photos on the Stovebolt site ...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
