| | | Forums66 Topics128,022 Posts1,055,353 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 72 | Well first off I must say thanks to the guys here. They are the best. Next question. I have my 49 GMC and am upgrading to power steering. I was going to keep the stock column but thought I would see if the column from my donor truck would work. It's a 77 GMC 1/2 ton. Will the column from that work? I have read that the best ones to get are from 70's vans, but might try the one from my 77. Thanks.
kskt4 | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Mine came from a '75. Took some fabriction to make work, but I like it now that it's in there, Scott | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | It might be easier to use the '77 column than the original.
Using the original requires cutting the column and shaft and locating a bearing to support the shaft. And then attaching to the end of the original shaft to connect to the new steering box.
My current thought is to look for a way to put the original wheel on a later column. Of course I plan to gain a turn-signal switch, automatic column shift and tilt wheel in the process.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Sep 2003 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 72 | Thanks guys, I will look into using the 77 column.
kskt4 | | |
