6 members (sron48, Charles in CA, Gray_Ghost, 66flea, Wally / Montana, dt235sd), 72 guests, and 1 robot.
Topics128,050
Posts1,055,757
#887320 10/06/2012 9:41 AM
My local tire shop isn't being much help with this so I'll need to go mail order. I'm looking for a source of quality tube flaps and inner tubes for 7.50x20 tires. Might as well add I'm looking for the best price on these items.
-Mike-
1945 Chevrolet G 506 1.5 Ton Military 4X4
1967 Jeep Cj5 with 283 SBC
sleeve #887328 10/06/2012 10:18 AM
Do a Google search
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
sleeve #887363 10/06/2012 12:53 PM
try universal tire in Pa.
www.universaltire.com
sleeve #887924 10/08/2012 4:56 PM
If there's a tire shop in your area that works on medium-heavy-duty trucks,they should be able to order the flaps/tubes that you need. I bought four tires a couple of years ago via the internet,and the P.O. stated that they were never mounted. They turned out to be 900.00x20.00's,which fit my 8.00x20.00-inch rims,but they were more than slightly WEATHER-CHECKED! Visually,they (the sidewalls) looked just fine,until they were mounted. That's when the cracks in the sidewalls appeared.I found out later that they dated back to WW-2! At least 10-years older than the tires they replaced!!Last week,I loaded her with about 5-ton of concrete slabs,drove her in "granny for about 1/4-mile before dumping the load,and now...all 4 drive tires need replaced! the side-walls split due to the extra flex from the load. I'm glad I didn't have to haul the load on the road! Usually,if one tire blows,it'll take out the one next to it. I learned my lesson! Buy NEW!!
Mo' Tater
sleeve #887946 10/08/2012 6:39 PM
Who has US made good tires that size? I see that China is making them and they are here already, I have 2 of them China crap tires on my truck, you spin the tire and the tread has a wave in it.Where do we find nice tires?
http://s1055.photobucket.com/user/baldybenny/library/
1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
Coker and Firestone make 7.50 x 20 non directional tread (NDT) military tires that are the correct size for WWII Big Bolts.Civillian tires too. The price per tire ain't cheap so first I'll get my tubes and flaps and then save my nickles and dimes to get the tires. It kills me that I'll pay more for the tires than I did for the truck!
-Mike-
sleeve #887957 10/08/2012 7:05 PM
I paid 1000.00 for some Cokers tires for my 36 coupe,And they were pass. tires.. There's no place else? Can we buy tires for under 200.00 each? Or is that just a dream now?
sleeve #887962 10/08/2012 7:14 PM
Considering that even tires for light trucks are getting to the $150-$200+ mark, you probably won't find heavy truck tires for any less than that.
Bill Burmeister
sleeve #887965 10/08/2012 7:16 PM
O Now that's good news! LOL.. Shell out more dough for the shoes for these trucks.
sleeve #887969 10/08/2012 7:33 PM
7.50's are getting very scarce, consider if you can fit 8.25's, which themselves aren't real common now but worked on my 46 1.5T .... and for drive tires, get Bandag recaps [now owned by Bridgestone], commonly used on big rig drives, the ones on my bus have been in place for 12-15 years, outdoors, and don't show any checking yet
sleeve #887978 10/08/2012 8:20 PM
Prices have really jumped in the past three years. I picked up a Universal tire catalog at Macungie. Local retailer slightly cheaper than universal. For comparision the tires on my work truck are running 550 to 650 apiece depending on manufacturer and design.
sleeve #887981 10/08/2012 8:29 PM
So can we run tires that have been weathered and not put a load on them? When is a tire dead?
I was always taught that a tire that is cracked and weather checked is an unsafe tire to use. Also consider that a tire that is old enough to be in that kind of shape has lost most of the traction properties out of the rubber and has very little pavement grip left.
My thoughts are tires that are old even if they look good are only suitable for low speed farm and ranch use and not safe for traffic or highway use.
-Mike-
sleeve #888279 10/09/2012 7:20 PM
1 Offline
I paid $1200 for 6 tires, flaps and inner tubes mounted and balanced at Les Shuab, They are 7.50x20 Power Kings.They are Chinese but balanced out true. I would definitally recommend the Power Kings on a 1.5 to 2 tonner. I am looking at buying 10 more for my 6x6, they have them in an aggressive tread that looks military for the same price. I'm middle class, and I just want drive my darn trucks.(safely)
1936 Chevrolet 1.5-ton SWB
"Murtahg"
More pix on Photobucket
It's only original once.
sleeve #888328 10/09/2012 9:26 PM
I have bought quite a few tires and tubes from these guys. The ones listed are Chinese, but I think thats about you can find in tube required.
http://www.nebraskatire.com/truck/overstocks.htm
