1 members (Eileen),
271
Mod | | | Forums66 Topics128,101 Posts1,056,181 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 15 New Guy | | New Guy Joined: Aug 2012 Posts: 15 | AFTER TAKING ANOTHER LOOK AT MY 46 COE,DOES ANYONE KNOW IF THIS IS THE ORIGINAL REAREND? HERE ARE SOME PICS.IT IS A FIVE LUG,BUT THE LUGNUT STUDS ARE WAY BIGGER DIAMETER THAN THE FRONT.ALSO IT LOOKS TO BE A MECHANICAL SHIFTED 2-SPD REAR. PHOTOBUCKET.COM
1979 Jeep CJ7 1946 CHEVY COE | | | | | Joined: Nov 2000 Posts: 1,399 Camp Commandant | | Camp Commandant Joined: Nov 2000 Posts: 1,399 | I can't say whether it is original or not but it doesn't look anything like mine, maybe some kind of special order deal? Mine is 10 lug on the back and all the lug nuts are the same, front to rear. This is the only shot I could find on my album but will take another shot of something specific if needed. http://rides.webshots.com/photo/2867988640083734483MyNAgz | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | It's hard to tell by the picture, but GMC used a 5 lug pattern on some trucks. The studs are larger than the typical Chevrolet pattern and the bolt circle is bigger as well.
If you found a set of rear drums and hubs from a Chevy, you could probably swap them out to make all four wheels match. It's pretty simple.
What does the bolt circle measure? And what size are the lugs?
Jeff | | | | | Joined: Aug 2012 Posts: 15 New Guy | | New Guy Joined: Aug 2012 Posts: 15 | Thanks Bill,I looked at your pic and sure enough there is some differences between the 2.I noticed that the housings looked the same,but the chunks were completely different.I don't have it home yet,but hoping in another 2 weeks,then I can really do some research on it.I'll keep everyone posted.
1979 Jeep CJ7 1946 CHEVY COE | | | | | Joined: Aug 2012 Posts: 15 New Guy | | New Guy Joined: Aug 2012 Posts: 15 | Thanks for the info Jeff.I'll be back over where the truck is this coming week to prep it for it's trip to it's new home and I'll be able to take some measurements.I do know that the lug nuts are bigger than 1",but I'll make sure.I'll keep you posted.Thanks Again!!
1979 Jeep CJ7 1946 CHEVY COE | | | | | Joined: Jul 2008 Posts: 413 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 413 | That looks like the same rear end that I have, it's an Eaton 1350 with vacuum shift. You have the bracket for the vacuum pod, but I see the pod is missing. Her's mine http://s675.photobucket.com/albums/vv111/JeffL_album/?action=view¤t=100_0857.jpgMy truck is a 45 GMC, mine is original to the truck. It is possible this could be your original, Im not sure if these were available on a Chevy or not.
| | | | | Joined: Aug 2012 Posts: 15 New Guy | | New Guy Joined: Aug 2012 Posts: 15 | You nailed it Jeff!After looking at your pics,It is identical to yours with the exception of the missing vacuum pot.Even the lug studs and nuts are identical.What are the gear ratios and are parts still available for these or would it be better to find a "newer" higher geared 2 spd?I'm making a tow rig out of it so it will need to go at super slab speeds.LOL!!
1979 Jeep CJ7 1946 CHEVY COE | | | | | Joined: Jul 2008 Posts: 413 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 413 | The ratio,s for that puppy are, High 6.33 low 8.81 Im not sure yet what is still available for these. I think you can still get all the bearings.
Just to verify that you have what I have, if you look up top next to the filler plug, the 6.33 ratio should be stamped there. below that should be the axle ID # which should read 26059.
| | | | | Joined: Aug 2012 Posts: 15 New Guy | | New Guy Joined: Aug 2012 Posts: 15 | Thanks for the info.I will check that out when I go over there tomorrow. BTW what size socket fits the rear lug nuts?My 4-way lug wrench fits the front but not the rear.I was going take a socket and breaker bar with me to remove one of the dual rear tires so it could be loaded on a roll back.
1979 Jeep CJ7 1946 CHEVY COE | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I'd guess 1-1/16" but that's just a guess, take an assortment. Why bother or have you measured? It'll fit as is on any rollback truck I've seen.
Grigg | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | That bolt pattern is 5 on 8" Modern, 22.5 wheels will fit on there, if one doesn't need to be original, those wheels are hard to find.
Look on '50's Dodge, IHC, etc.
| | | | | Joined: Aug 2012 Posts: 15 New Guy | | New Guy Joined: Aug 2012 Posts: 15 | Well,I finally got the truck home this evening,more like dark thirty.I will take a better look at the rear end now that it's here.I did notice while the truck was on the roll back the removable plate on the back of the rear end read GMC.I'll know more tomorrow.
