| | | Forums66 Topics128,101 Posts1,056,180 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 26 New Guy | | New Guy Joined: Sep 2012 Posts: 26 | Hey gang. I'm casually working my way towards a COE rebuild- no body yet. I have many questions of ignorance on this process!!
So I'll number my questions if you can answer them as needed. 1) S10 Chassis: I see lots of posts with rebuilds using and S10. Why? Is it the narrow frame?
2) Related: Why not a larger frame?
In my mind, I have about 10 ideas for what I want to do with a COE- I suppose based on the body I end up getting. I KNOW I want to lower the body and have a "modern" drive train.
So, my thoughts are to find the right body, do enough body work to get it paintable, then look for the "right" chassis (and finalize my project goal) (camper, motorcycle hauler, tow vehicle, who the heck knows?).
I see great ideas on a FWD motorhome chassis, moving the engine behind the body, and so on.
I've searched posts and in some searches I'm getting so many returns that I don't know where to start.
Thoughts?
Grant Holmes "Casually" looking for a decent COE cab (chassis not needed).
| | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | I think the larger frames will be too wide and the front tires will stick out to far . http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
| | | | | Joined: Apr 2001 Posts: 199 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 199 | I am not sure what year you ar looking for but the older trucks tend to be a lot narrower than new trucks. I used a GMC4500 ( same as isuzu npr) for my truck. Here is my build pictures. I use it for a tow pig for our camper. http://rides.webshots.com/album/580587250vqfuun | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I've chosen to update the original frame with newer axles and brakes, and swap in a Diesel engine. https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=725027#Post725027I want a very stock appearance; imagine how they would have done it back in 48 if the Detroit 4-53T and disc brakes were available. To get what I want starting with the stock frame/truck and only modifying or changing what's necessary is the best way. Grigg | | | | | Joined: Sep 2012 Posts: 26 New Guy | | New Guy Joined: Sep 2012 Posts: 26 | Bugsy. WOW, that's a LOT of fab work. Nice!!!!!
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Building a tow rig or a truck that will haul "who the heck knows" means that the s-10 chassis front end will be too light so immediately your left with swapping in and using something heavier. That would account for the FWD motor home chassis or perhaps getting an Eldorado chassis or similar. Personally I would build my own frame and decide what I needed for the job as to the suspension(s) and running gear.
Might as well make a complete custom as to start chopping something old up if you want a modern cruiser. 2"x5" tubing works well and crossmembers can be salvaged from a wrecking yard. Truck frames are a fairly simple and straightforward design. | | | | | Joined: Sep 2012 Posts: 26 New Guy | | New Guy Joined: Sep 2012 Posts: 26 | So... when I do find that magical COE I can afford and wants to come home with me... I understand your points as...
1- If it's gonna be a simple "pick up" truck, I could probably use an S-10 frame. Is there a "magic" year for S-10's that is best?
2- Heavier uses, towing/hauling something heavy (car on trailer or on the truck?) I may want a heavier frame.
3- I could build my own frame... (Dave: HELP!!) Any links/suggestions on ideas? Not that I don't understand the concept, but where to start, then hanging especially the front suspension? I imagine the rear is fairly/relatively simple?
I know I don't have a truck yet, but it sure is fun to scheme!!!
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Schemes lead to plans and plans can lead to action. So scheming is not a bad thing IMO. Like most however a lot of my schemes never lead to a plan of action. But I still enjoyed it. | | | | | Joined: Apr 2001 Posts: 199 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 199 | Planning is one of the most important parts. I had been planning and thinking about big bertha for years. Once I had the truck, it took a lot more planning. When i executed my planning I was about 50% spot on and had many oh on monoments. Take your time and alot time for re-dos. if you think it is going to take an hour...plan on 4 hours. Good luck and happy planning | | | | | Joined: Oct 2008 Posts: 126 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 126 | Pick the year/body style truck you really want to own the most. The one that really turns you on the most. Then shop the Internet for other trucks of that year & find one or two that was done the way you would want your truck to look like. "work truck/wrecker/lowrider/hotrod/ratrod/exc,exc" Then while you are looking for your dream truck project, you can start on a frame/suspension. But I would think that it would be best to have a cab near by for measurements before cutting & welding on a chassis??? Hard to finnish what you start if you don't like what your working on.
Darrell, W.L. 1939 Chevy COE tow truck/My Stubbed toe 1939 Chevy 2 door Sedan
Car chat means talks about Chevy's. All other car makers only build transportation. I don't work on my cars, I entertain my self in my garage, so my nabor tells me.
| | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | Is that a wrecker Oldschool? Nice rig! http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
| | | | | Joined: Oct 2008 Posts: 126 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 126 | Yes it was a Wrecker. I am planning on air bagging it and slamming it to the ground...
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I put a set of modern disc brake axles, w/ associated Saginaw power steering, hydroboost brake setup, 4-53T, RTO-610, Brownie 6231 aux. trans. under a 2 ton, '37 GMC chassis and body, sort of like Grigg's. See '37 GMC build here under 'Builds.'
| | | | | Joined: Oct 2008 Posts: 126 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 126 | Grant Homes; I just got the perfect frame last weekend for my 1939 Chevy COE tow truck body. I found a 1980 GMC 1 ton Van. One of those potato chip/bread Vans. It's a 20' long frame, so I will be cutting it shorter, but the frame rails are same as my original 39 frame rails. So my cab mounts will sit perfectly on it. Steering box is in exact spot as my original. The kicker is, independent suspension, with power steering & power disc brakes & the front hubs are same width as my original. So I can use original style reverse type wheels. It is all set up for a V8 or whatever I choose. The Van had a Diesel motor. If you can find a complete early 1980s GM 1 ton Van, a driver. You should be able to set a cab of any early GM COE right on it & drive it away... ...kinda sorta... I plan on airbagging mine, this front suspension already has the shocks mounted outside the coils which will make airbagging it easy... PSSSS, I am looking for a better grill for my COE, 1939 or 1940 will work, parts grill will help to...
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | oldschoolchevy, what type of wrecker unit was that on your truck? Do you have the crane unit also, or just the service body you have pictured. | | | | | Joined: Oct 2008 Posts: 126 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 126 | Hi Spanky; Sorry no crane. I know you get excited over some of those units, but this bed was blank. Even the floor & & inner side wall wood had rotted away. The only thing left that I'm not using would be side draft carb. & air cleaner, foot starter button with linkage, clutch & brake pedals with linkage. Not much more that I can think of. I sure wish someone could come up with a better grill for me...
