1 members (delky), 65 guests, and 2 robots.
Topics128,049
Posts1,055,740
#88547 12/27/2002 5:15 PM
58 apache, fuel gauge not registering, ground the wire and the gauge shows full. how much resistance should the sending unit have ? or would it be easier just to replace it?
thanx
Sometimes I wrestle with my demons, sometimes we just cuddle
#88548 12/27/2002 9:30 PM
smile howziit Mike!
i had the same problem in THE PINK LADY('56 3100 series).
although the sender looked new(from the outside), it always showed EMPTY.
not wanting to mess with it, i simply replaced the sending unit...and the shoddy wiring.
upon inspection, i discovered that the brass float was full of gasoline, but the 30-ohm resistor still worked well.
Myron
1956 chevy 3100 stepside, Pro-Street stance, mild 454 BBC/350/9"/13" M/T'S, daily driver, aka THE PINK LADY
1957 Bel-Air coupe, 500 HP blown sbc in progress, aka LANI
#88549 12/28/2002 12:06 AM
I bought one of these and was real pleased with it. Easy and fast to install. Yogi\'s Fuel sender Joe
#88550 12/28/2002 4:21 PM
Thanx for the info and quick response. Will doublecheck resistance on sender and also float integrity, possibly replace unit next payday. thanx again
#88551 12/30/2002 5:06 PM
Gator mike if it is the float they are real inexpensive around $5 or so. My sending unit was frozen with rust got it free replaced the float and it works great. Well except the one time I ran out of gas cause I didn't know EXACTLY where empty was! This spring I will ADJUST the float arm!
Good luck!
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
