| | | Forums66 Topics128,281 Posts1,058,471 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#88547 12/27/2002 5:15 PM | Joined: Dec 2002 Posts: 12 New Guy | | New Guy Joined: Dec 2002 Posts: 12 | 58 apache, fuel gauge not registering, ground the wire and the gauge shows full. how much resistance should the sending unit have ? or would it be easier just to replace it? thanx
Sometimes I wrestle with my demons, sometimes we just cuddle
#88548 12/27/2002 9:30 PM | Joined: Sep 2002 Posts: 72 Member | | Member Joined: Sep 2002 Posts: 72 |  howziit Mike! i had the same problem in THE PINK LADY('56 3100 series). although the sender looked new(from the outside), it always showed EMPTY. not wanting to mess with it, i simply replaced the sending unit...and the shoddy wiring. upon inspection, i discovered that the brass float was full of gasoline, but the 30-ohm resistor still worked well.
Myron
1956 chevy 3100 stepside, Pro-Street stance, mild 454 BBC/350/9"/13" M/T'S, daily driver, aka THE PINK LADY
1957 Bel-Air coupe, 500 HP blown sbc in progress, aka LANI
#88549 12/28/2002 12:06 AM | Joined: Feb 2000 Posts: 5,268 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,268 | I bought one of these and was real pleased with it. Easy and fast to install. Yogi\'s Fuel sender Joe | | |
#88550 12/28/2002 4:21 PM | Joined: Dec 2002 Posts: 12 New Guy | | New Guy Joined: Dec 2002 Posts: 12 | Thanx for the info and quick response. Will doublecheck resistance on sender and also float integrity, possibly replace unit next payday. thanx again
#88551 12/30/2002 5:06 PM | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | Gator mike if it is the float they are real inexpensive around $5 or so. My sending unit was frozen with rust got it free replaced the float and it works great. Well except the one time I ran out of gas cause I didn't know EXACTLY where empty was! This spring I will ADJUST the float arm!
Good luck!
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
