| | | Forums66 Topics128,093 Posts1,056,463 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 121 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 121 | What are the correct size brake lines for a 51 AD truck ? I bought all new brakes lines and a master cylinder for 51. The lines seem small . I was thinking they maybe gave me the wrong lines . I purchased the parts from the truck and car shop in orange ca. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | What size truck is it? '51 1/2 tons use 3/16" line for all, 3/4 ton and larger use 1/4" line exept for the line across the rear axle, which is 3/16".
Bill Burmeister | | | | | Joined: Apr 2009 Posts: 121 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 121 | It's a 1/2 ton , I'll measure the lines and make sure they are right . | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ....isn't there a 1/4" line going from the m/c over to the right side block? Seems I remember ONE 1/4" line going somewhere on my 52 1/2ton...or maybe I'm just getting old? | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | No, not old, you are correct. The line from the MC to the distribution block (front to rear) on the right frame rail is larger than the rest. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The '52 may be different from the '51. The specs I posted are from the '51 shop manual.
Bill Burmeister | | | | | Joined: Apr 2009 Posts: 121 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 121 | The lines are 3/16" . Im having a hard time finding the brass T , anyone know I can located it ? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Try JimCarter as I remember seeing some before...or maybe classic parts or American Classic
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Chevs of the 40s Call them to make sure they have the right diameter. Jim Carter most likely has them, but their site is no good with a tablet PC. | | | | | Joined: Apr 2010 Posts: 114 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 114 | Inline tube.com has nice stainless correct size lines, tees and even nice actual length brake quality cables, compared to other cheap junk out there..... | | |
