3 members (JW51, Otto Skorzeny, 1 invisible), 112 guests, and 4 robots.
Topics128,269
Posts1,058,402
Members48,485
#882411 09/13/2012 6:12 PM
What are the correct size brake lines for a 51 AD truck ? I bought all new brakes lines and a master cylinder for 51. The lines seem small . I was thinking they maybe gave me the wrong lines . I purchased the parts from the truck and car shop in orange ca.
What size truck is it? '51 1/2 tons use 3/16" line for all, 3/4 ton and larger use 1/4" line exept for the line across the rear axle, which is 3/16".
Bill Burmeister
It's a 1/2 ton , I'll measure the lines and make sure they are right .
....isn't there a 1/4" line going from the m/c over to the right side block? Seems I remember ONE 1/4" line going somewhere on my 52 1/2ton...or maybe I'm just getting old?
No, not old, you are correct. The line from the MC to the distribution block (front to rear) on the right frame rail is larger than the rest.
The '52 may be different from the '51. The specs I posted are from the '51 shop manual.
Bill Burmeister
The lines are 3/16" . Im having a hard time finding the brass T , anyone know I can located it ?
Try JimCarter as I remember seeing some before...or maybe classic parts or American Classic
Chevs of the 40s
Call them to make sure they have the right diameter.
Jim Carter most likely has them, but their site is no good with a tablet PC.
Inline tube.com has nice stainless correct size lines, tees and even nice actual length brake quality cables, compared to other cheap junk out there.....
