1 members (klhansen),
124
9
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Just thought I'd pass this on.
Two weeks ago I was driving my '41 with the windshield cranked open and had something come in under the windshield and get into my eye. I was doing 50 MPH on a paved country road with nobody in front of me. It must have been a bug or bird (droppings) because two days later it was infected. I spent 5 days in the hospital after minor surgery to remove an abscess from the eye. I was wearing glasses (can't drive without them), but should have used larger sunglasses.
That open windshield is fun, but you gotta be careful
Kip
| | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | try a mad hornet in a full face helmet at 70 mph....  | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Ouch !......hope your eye is OK. Guess I need to keep my eyes closed in the future *g* | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ..yep'er, had a few coming "flying" under my 37. Been lucky so far. They are really bad about sundown.
Kip, hope all is well now and thanks for a good safety tip. I'll also pass it on to the little short lady. | | | | | Joined: Apr 2009 Posts: 252 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 252 | Dang Kip, Hope your doing well and thanks for the heads up! | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Kip, Glad you're OK, could have been worse. I learned my lesson driven on the freeway with the windshield open. NOT a good thing. It's kind of nice if you are puttering along less than 40, but one should still be carefull. George | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Thanks for the kind words.
According to the pretty blue eyed, blond doctor I should be "just fine" in another week or so. For now with my left eye covered that huge left front fender makes parking a problem. | | | | | Joined: Mar 2008 Posts: 374 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 374 | Duly noted, I will take this into consideration when driving with the window cranked out. Glad you're okay Kip!  | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | Thanks, Kip, for the heads up. We generally don't go over 40 mph unless somebody is on our butt, and that air coming in is great when it is 95 degrees or so, like it's been this year. But, thinking about it, that type of ventilation was designed for low speeds. If your truck is geared for freeway cruising, close that windshield! That's like riding a motorcycle without goggles or a face shield! I learned that a LONG time ago.
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | |
