Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (Wayne67vert, 78buckshot, 1 invisible), 78 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#878766 08/29/2012 12:47 PM
Has anyone converted from the floor stomp start to a key start on their 47-53? What key setup did you find to be best?
TIA
Dennis
oldbluetruck #879300 08/31/2012 12:56 PM
k10 Offline
You could go over to a boating supply place and see what they have. you'll need to figure out whether you want a 2 position or a 3 position switch. Cole-Hersee is still made in Massachussetts, for one brand. The Marine stuff should be better than the Off Shore stuff. Ha, that's pretty funny actually.
http://www.colehersee.com/home/grid/cat/88/
k10 #879323 08/31/2012 4:13 PM
Remember you have to change the switch on the starter to a solenoid type too. I bought my dash switch at NAPA.
Drew
DrewP #880140 09/04/2012 10:56 AM
Thanks for the replys. I do have the starter with the plunger solinoid, so that is fine. My engine is from a 52 chevy and I think the car had a push button start but do not know what they used. I bought my ignition switch at NAPA also. The only problem I found was it doesn't fit real well and rolls around or twists.
I thought someone had changed to a key start and has found a real good key starter or found a way to install theirs. I like to take advice. I did not want to reinvent something that they found works.
Thanks again.
Dennis
oldbluetruck #880162 09/04/2012 1:05 PM
if the starter is from a car, I don't think it had a push button, try Chevs of the 40's or Filling Station for a car ignition switch - which looks like the 55-59 truck switch, which would also work if it fits the hole
Flxible #880203 09/04/2012 4:38 PM
I have a 58-58 TF switch and it does not fit.
Dennis
oldbluetruck #880227 09/04/2012 6:45 PM
thought you had a NAPA sw? a forklift generic variety? - if the 58 sw is too big, ream out the hole - if it moves around it's cuz there's a ridge on the switch that fits a notch in the dash hole to prevent that and your dash doesn't have it - should be a way to fix that, maybe a piece of sheet metal cut right and put behind the dash?
