| | | Forums66 Topics128,006 Posts1,055,267 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Has anyone converted from the floor stomp start to a key start on their 47-53? What key setup did you find to be best?
TIA
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | You could go over to a boating supply place and see what they have. you'll need to figure out whether you want a 2 position or a 3 position switch. Cole-Hersee is still made in Massachussetts, for one brand. The Marine stuff should be better than the Off Shore stuff. Ha, that's pretty funny actually. http://www.colehersee.com/home/grid/cat/88/
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Remember you have to change the switch on the starter to a solenoid type too. I bought my dash switch at NAPA.
Drew
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Thanks for the replys. I do have the starter with the plunger solinoid, so that is fine. My engine is from a 52 chevy and I think the car had a push button start but do not know what they used. I bought my ignition switch at NAPA also. The only problem I found was it doesn't fit real well and rolls around or twists.
I thought someone had changed to a key start and has found a real good key starter or found a way to install theirs. I like to take advice. I did not want to reinvent something that they found works.
Thanks again.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if the starter is from a car, I don't think it had a push button, try Chevs of the 40's or Filling Station for a car ignition switch - which looks like the 55-59 truck switch, which would also work if it fits the hole Bill | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I have a 58-58 TF switch and it does not fit.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | thought you had a NAPA sw? a forklift generic variety? - if the 58 sw is too big, ream out the hole - if it moves around it's cuz there's a ridge on the switch that fits a notch in the dash hole to prevent that and your dash doesn't have it - should be a way to fix that, maybe a piece of sheet metal cut right and put behind the dash?
Bill | | |
