1 members (classicchevs), 101 guests, and 2 robots.
Topics128,093
Posts1,056,474
Members48,444
#878362 08/28/2012 9:32 AM
1948 1.5 T 161" wheelbase. I have the rear drive shaft off the truck, it has needle bearings in the rear u-joint.
I was able to remove the shaft because the connection to the rear end had the two typical u bolt connections. The 2 other ends are in the rear yoke on the drive shaft. It doesn't come apart. I removed the spring clips from the ends but can't figure out how to remove from the yoke. On a typical joint I would drive them out with a drift/punch but these joints have a cap on the inside of the yoke and nowhere for the cap to go if I start hammering on one side.
So, that is the question, plus, where can I get the new joint? for a 1.5 ton? local FLAPS?
I searched the archives without a definitive solution, looking to you guys for help. Thanks, Motoswiz
1948 Chevrolet 1.5-Ton Dually
More pix on Photobucket
Motoswiz
North Florida
You need to hammer them back and forth from side to side until you loosen up the caps enough to work them out. Sometimes these things are stubborn. A piece of pipe or an old socket that just fits works really good as a driver. Use lots of lubricant and take your time. All that old rust, dirt and grease makes them a b*tch sometimes.
You should be able to get them at your FLAPS. Try Precision 331, it seems to be a fairly common one. I don't know what it crosses into for other brands.
Jeff
My 1953 Chevrolet
1947.1 Gallery
It is most likely a Spicer 1350 series joint
•1952 Chevrolet 3800 pickup
---All pictures---
thanks for the reply RN...
I thought that was the way but wanted to ask to be sure i didn't mess up something that I couldn't get easily...we all know how that goes...
funny how one thing leads to another...
I finally got time to put on the new brake hoses after redoing all the "in the wheel parts" last year...decided to replace the rear hard lines, while off, clean the rear-end...removed the rear drive shaft to make it easier to clean back there, decided the u joint needed replacing, and the list goes on...hahaha
thanks again, Motoswiz
Motoswiz
North Florida
Update: back and forth with PB and ATF got it loose. Off to NAPA to see if they can get me a replacement. thanks to all...
MS
Motoswiz
North Florida
