1 members (baldeagle),
94
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 15 New Guy | | New Guy Joined: Dec 2009 Posts: 15 | Hello from England.
I have a 61 apache with a 235 in it. It used to run really nice, but recently has developed a big problem. Before, it ran with a good, clear exhaust tone - now it sounds like it is not just mis-firing, but that the "spark" is all over the place. I initially thought it was the condenser/coil breaking down - I replaced the points etc. with an electronic ignition and also replaced the coil...... no change at all. I set the crank to the "ball" on no.1 compression, and moved the distributor to the point that it made a spark at the plug - it will hardly run at all. I also replaced the carb to see if that made any difference - not at all!
Is there a chance that the timing chain has slipped????? Is this something that happens to a 235?????
Is there any other way I can check to make sure the timing is correct??
Please let me know,
Thank you.
Laine | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Laine, the 235 doesn't have a timing chain, it's gear driven. Did you change the dist. cap, rotor? Check the ignition wires they get old and break down to. If it's misfiring the cap could have a crack in it, the wires could bedamaged ( some wires are not real wire ). I then would start the engine and play with the timing, advancing it slowly and see what happens.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | You have timing gears,no chain. It is possible something could be broke with them, but I would make sure the distributor is working properly first. Check for points wear or looseness. If they check out ok, it's possible the distributor mount is loose.Check that. Lastly,if necessary, pull the distributor and check for shaft wooble and shaft cam gear for damage. it might be timr for a rebuild or replacement of it.
Drew
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I'd pull the #1 spark plug and get the motor on TDC, then take the distributor cap off and make sure the rotor is pointing at the #1 terminal in the cap. Then you'll know if your timing gears let go or if you need to look at other stuff. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Sounds like the timing is slow. Setting it with out running is just preliminary. Use a timing light & set it sveral degrees beyond the ball. If not move it up a bit &b try it. Set it where it runs the best. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | The PO for my truck (with a 61 235) said that he had installed an electronic iginition on this and it did not run well at all. He called Patrick's and the first thing they told him was to get rid of the electronics and go bad to the original system which he did and it just purred. Any continues to. | | | | | Joined: Feb 2005 Posts: 36 New Guy | | New Guy Joined: Feb 2005 Posts: 36 | I have a Pertronix kit in my 56 235 and it works great and has for years. I'm sure it could cause a problem but condemning them all isn't right. Personally I'd be weary of anyone that made a statement like that and I sure wouldn't buy parts from them. I think basic troubleshooting should find the problem pretty easily. | | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | Follow the suggestions you got so far first. If you still have problems pull the distributor and check for excessive lateral movement in the shaft. Check the drive gear. Both that it is tightly pinned to the shaft and the teeth are in good shape.
Chuck | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Run a ground wire from a distributor clip nut to a coil-mounting bolt (make sure wire contact surfaces are clean). | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Also make sure that you have 12V going to the coil. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | "Personally I'd be weary of anyone that made a statement like that and I sure wouldn't buy parts from them".
rue: taking a shot at someone having the stature of Patrick only cause's me to think your more than just a "new guy" here.
FYI Patrick is a highly respected person of genuine knowledge and as a supplier he is probably without equal.
Forum rules prohibit your type of comment. | | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | I am sorry if my comments offended anyone. I passed on the comments from my PO regarding Patrick's only to be helpful since it was from a more-than-credible and respected source. My own bias is to restore these old guys as they were originally designed and engineered and that is why I latched onto the view that the new electronic stuff doesn't always suit 60 year olds. Except for my maybe pacemaker! | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Follow the suggestions you got so far first. If you still have problems pull the distributor and check for excessive lateral movement in the shaft. Check the drive gear. Both that it is tightly pinned to the shaft and the teeth are in good shape.
Chuck I once had a similar problem with random spark, I inspected my distributor and did find a loose drive gear ...click... Picked up a new distributor at NAPA (They had on the shelf) and no further problems 235, pertronix Good Luck | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | How old is the dizzy cap? I've had them go bad and act similar to your conditions...
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | Forum rules prohibit your type of comment.
Why? | | | | | Joined: Feb 2005 Posts: 36 New Guy | | New Guy Joined: Feb 2005 Posts: 36 | I don't think my comments were out of line at all. Electronic ignition is a well proven technology. Condemning them all when someone has a problem they are trying to fix IMO is wrong no matter who you are.
I've never had any dealings with that guy or his company so I have no axe to grind there. Just making a comment.
| | | | | Joined: Jul 2012 Posts: 93 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2012 Posts: 93 | kinda reminds you of the Inliners dont it?
