2 members (klhansen, Hotrod Lincoln), 89 guests, and 0 robots.
Topics128,050
Posts1,055,641
#876537 08/21/2012 8:24 PM
on my 55 ist with stock 6 volt 235 engine - when cold, the engine starts right up. i drive for about eight miles and it will die - no backfiring, just quits. if i try to start right away, it won't fire. if i leave it for a few minutes, it will start up again. don't think it is a gas problem. if not gas problem, would it be a bad coil?
I just went through this exact same problem. After replacing the rusted gas tank, clogged filter and rebuilding the carb I still had the same problem as you.
Replaced the coil and TADA.
1951 Chevy 3100 5-Window
"Howard"
More pix on Photobucket
a bad condenser can act that way also
