1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 39 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 39 | on my 55 ist with stock 6 volt 235 engine - when cold, the engine starts right up. i drive for about eight miles and it will die - no backfiring, just quits. if i try to start right away, it won't fire. if i leave it for a few minutes, it will start up again. don't think it is a gas problem. if not gas problem, would it be a bad coil? | | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | I just went through this exact same problem. After replacing the rusted gas tank, clogged filter and rebuilding the carb I still had the same problem as you. Replaced the coil and TADA. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | a bad condenser can act that way also | | |
