Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
8 members (cmayna, ShopRag, Cosmo, Eisenholtz, 1955 1 Series, Bill Hanlon, Mike Roache, 1 invisible), 58 guests, and 3 robots.
Topics128,020
Posts1,055,267
Members48,418
Page 72 of 177 1 2 70 71 72 73 74 176 177
got my nostalgia sid's 3" drop axle in my 46 1/2 ton, got the steering arms, drag link, and tie rods all in and working!!11
Got my $20 gas tank all fitted up. Welded up some brackets and put a high pressure pump on the sender to feed my 5.3. Now it is time to strip it down and get the frame blasted and ready for por-15.
http://s960.photobucket.com/albums/ae90/scrambler45/
Brought home the possible new 235 for the 37,it supposed to have less the 20,000 miles but is a little dirtier then I was hoping on the inside. Going to make something so I can fire it up and see how it runs before putting it on the stand,I am going to tear it apart this winter to check the condition and hope to get by with just a reseal.
Originally Posted by bigbassmann
Got the rebuild kit installed in the Edelbrock 1405 carb. Going to drain to old gas out of the tank tomorrow and put in some fresh gas, put in new points, condenser and rotor button, check the plugs, install the freshly charged battery, put the carb back on and hopefully get it fired up and running. It has been sitting for over a year now and I have a hankering to get him back on the road.
Well, I got all of that done today and got it fired up and running, at least for awhile. Never could get the idle set just right, it would be a bit too high and when I tried to adjust it it would fall off too much and stall out. Finally quit about lunch time at which point I had to keep a little throttle to it to keep it running and then it just shut off. Figured it was out of gas so this evening I went and filled up my 5 gallon can, came back and poured that in and still couldn't get the engine to fire up. Looked at the clear inline fuel filter and it was almost dry. Guess I need a fuel pump now and am wondering if that was why I couldn't get the idle adjusted properly.
Ralph Davis
1970 Chevy C10 Webshots
My Stovebolt Gallery page
Old trucks never die, they just find a new home.
Please ask engine related questions in Engine Shop.
Thanks.
I finally got it shifting right again.
I had transmission problems with the burb so I had a shop work on it. I got it back and it wouldn't move in reverse. The guy told me to bring it back so I pulled it again. Once I got it out I realized it's a linkage issue. One of my shift rods had a threaded adjustment. The threads were worn where the chilibob is and instead of going into reverse the chilibob would slip on the threads.
I got the tranny back in and tried to adjust the rod to new threads but there wasn't enough throw in the shifter to work that way. I went out to my parts trucks and found a clamp on chilibob. Works as it should now.
I also put lock washers under the nuts on my axle U-bolts. Last Sunday as I was leaving the Inliners meeting a guy noticed my shock hanging loose. I had lost 2 nuts. I limped it to two different auto parts stores and neither had 1/2-20 nuts. I ended up pulling one from the other side and came on home with 3 to a side.
While I was under there I gave it a grease job.
I'm going to Kansas City, Kansas City here I come.
I started to install sound deadening mat throughout the cab,the difference is amazing especially on the roof.
More pix on Flickr.
Thanks.
Cletis, I assume this was directed at me. I wasn't asking a question, just stating what I had done today and wondering to myself if the idle problem was fuel pump related. I wasn't expecting an answer. Sorry if it seemed I was asking for guidance.
Ralph Davis
I cut the rusty bottom out of the passenger door on my '59 project and then cut the patch panel to be welded-in. I might install the door mechanisms while I have some additional access. Then will come my first ever time to weld anything... wish me luck!
With the weather what it is in Scotland you won't have a problem, but here in Texas where summer could find a 110 degree day I would remind folks it would be smart to insulate against the heat on that roof. I used SolarShield and can really tell the difference.
~Jim
Got a bit more done on the stake sides over the weekend. Added a removable board over the gate that slips in between the end pieces and is held in place with removable 1/4" pins. ...I'm pretty proud of the whole shebang. Came out pretty nice for eyeballing the entire thing.
Still needs a couple flat washers, lock washers all round, a bit more sanding and a few coats of varnish.
http://rustyfiftyone.com/2012/08/13/makin-progress/
Jim,i'll probably overlay the pads in the roof with some form of heat reflective insulation anyway, if only for the soundproofing and condensation reduction.
Maybe even for the odd day or two when it breaks 70 degrees! ohwell
More pix on Flickr.
[/quote]
Maybe even for the odd day or two when it breaks 70 degrees! ohwell [/quote]
Yeah, and I'm jealous.
~Jim
back yard wrench turner
This is the heat shield material I used.
heat shield
It is a heavy felt like fabric under the foil. I bought it on ebay.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Today I finally painted my front fenders and the trim around the cab and hood.
fender
trim
Wayne
1989 Silverado
heat shield
Thanks Wayne,that's the stuff I had in mind.
BTW your truck's looking great!
More pix on Flickr.
Big Bolt Forum Co-moderator
jockbolter50, that truck looks cool withe fenders off too. With the heat shield, what do you put over it? Is there a material like the headliner that covers the entire enterior?
1948 Chevy 2-Ton
Jockbolter50, Thanks
Super55,
There are metal panels that cover the inside, except behind the seat and the headliner areas.
I am also using it in the doors, on the inside of the firewall and under the future carpet.
The truck sits way too tall for leaving the fenders off.
Wayne
1989 Silverado
I have an AD, a 1948, that I bought the Eastwood product for when Eastwood was having a sale. I am going to do the cab, including the area behind the seat. I think I'll try to find a suitable material that isn't too flimsy to cover the insulation where the headliner and floor mat don't cover cover.
1948 Chevy 2-Ton
Wayne's cleared that one up,it's his truck after all.... thumbs_up
The AD series trucks have the fixed inner skin around the rear window.
The headliner will hide the roof insulation but i'm still not sure what to do behind the seat.
More pix on Flickr.
Got my gas tank back in after sealing it up with Por-15,the brakes are all finished up. Just gotta pick up the new lug nuts from Napa in the morning and take it for my first drive! Can't wait!
1953 1 ton panel
[/quote]Originally Posted By: Super55
i'm still not sure what to do behind the seat. [/quote]
I found a sheet of thin white plastic that is textured on one side that I'm using for the headliner, behind the seat and kick panels. It should accept paint well and let me glue my cow hide to it for the headliner.
Wayne
1989 Silverado
Going to pick up my drive shaft in just a little while. Should be riding by tomorrow. I've got to adjust the brakes and replace the pinion seal. The new one wasn't right so it leaks.
1949 Chevy 1/2-Ton ~ Red Truck
More pix on Photobucket
...and let me glue my cow hide to it for the headliner.
Nice! I was thinking of doing the door panels and headliner in an old tan and white steer hide floor throw rug thing I have that has seen better days.
Went over the nuts and bolts on the 37 today. Adjusted the carb,greased it up good, changed oil and checked all lines and filters.
Plans are to make a run to Ga. this weekend for a "gathering". All I need now is to wash it!! Woog, I'm on my way!!
Also got my tranny cover from a fellow bolter and have it about 75% ready to paint or POR15. Another day gone....but another one coming smile
Watch yourself on the trip, plenty of nuts (not speaking of your hardware)on the road.
~Jim
I sand blasted my front bumper mounts in a friends sand blaster.
Got to get me one of those!
Gave the mounts a good old lick of POR-15,just waiting to give them a second coat.
More pix on Flickr.
Kids first day of school, so drove them to school, took day off, and .. since i had a few hours to play with...
Took head of my 216. Note to self: head will not come free unless ALL bolts are off. PO did nice job of painting over grease. ... Pistons looked pretty good; scrapped "loose" carbon off top with razor blade, degreased, more cleaning tomorrow. .. of course i sheared bolts off manifold (exhaust to muffler pipe, and exhaust to intake.,). Going to leave that to machine shop as I can never extract sheared bolts. Good day.
1951 Chevy 3100
Goin' to a cruise-in and show on Saturday, so I greased all the fittings and checked all fluid levels. Hope the weather is nice, but also made sure the vacuum wipers are working.
I got the front clip back on!
pic!
josh
I bought the EP and paint today. Along with some other tools and supplies. wooohooooo! She's gonna be sooo purdy! grin
I started cleaning up the 'burb with CLR, Scotchbrite and elbow grease then applied lemon Pledge. It makes a difference.
Front end
Back doors
Front end
Back doors
Looking good Cletis,mind you with that left rear door window seal,if it was over here you'd be driving a mobile swimming pool! lol.
More pix on Flickr.
When I was a teen I worked as a delivery boy. We had two vehicles that I drove; one was one of the first Ford Econolines and the other was a 1954 Chevy panel truck. It seems to me that they must have made a bunch more panel trucks than Suburbans but we don't see them now. Just wondering...
~Jim
That aint the half of it. Rain pours through the windshield.
-unloaded the donor 12bold form my DD
-dry fit the 216 back together to sell and to make room!
-cut off all unneeded brackets and whatnots form the frame!
-pressure washed the frame from acid treatment round one, started last night!
-got jiggy with the wire brush!
-second coat of acid treatment!
-Pressure washed and rinse... back in for more wire brushing...
-Primered a few areas....
Pretty much a repeat from the last 4 days...
Nothing exciting....
-Jerry
PS...
I'd rather be waxing it tho!!!! Nice post!
After searching for a year I found the next project!
46' 1/2 ton in pieces! took 2 trips to get it home, but most of the hard work was already done!!!
-jerry
"Phil" the 46'
Put the front fenders on and cleaned the carb to fix sticking float. smile
Wayne
1989 Silverado
Took the horn apart on my '51 burb and cleaned the contacts. Boy does she toot.
kurt
Changed the oil in Olblue.. really needed to be done so I put in 10W-30 as the local stores didnt have the standard SAE 30... It feels good to have clean oil in there but my hunch is the lower viscosity will smoke more at start up..
1950 Chevy 3600
Instagram/Olbluechevytruck
on Classic trucks:
http://rides.classictrucks.com/ride/1085750/olblue/1950/chevrolet/c20/
Y
Y Offline
Repaired, cleaned, sealed, installed gas tank in my 53 burb. Formed, fitted repop left side floor/toeboard and kick panel in the burb. Next week will weld and hope to prime and seal completed work.
