4 members (CuzzFuzz, baldeagle, Ponchogl, Stovebolt48), 68 guests, and 6 robots.
Topics128,021
Posts1,055,346
Members48,420
#874458 08/13/2012 2:37 PM
Going to try to get the dump bed off tonight!!! Anyone got any advice on getting it off with a 3 ton granny hoist?
brickman #874533 08/13/2012 7:52 PM
I'm not someone that really knows anything, but is it possible to jack up the bed and drive out from under it. Use the hoist to lift the bed then brace it.
Please someone with actual experience comment.
EricJ #874579 08/13/2012 9:37 PM
I cheat, I use my Cat...Are you pulling just the bed or bed and all? I pull just the beds onto another flatbed truck using round fence posts as rollers
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
48bigtrucks #874599 08/13/2012 10:33 PM
Scott
I did the same with mine, I'm not re using it so I put it on rollers and pulled it off with a rope attached to another truck.
Jake45 #874666 08/14/2012 11:23 AM
I wish I could have cheated and used a cat. I had to use a little elbow grease and some good old brain power. But I after a few hours I end up getting!!! Thanks for all the advice guys!!!! I added some new pics to the gallery!
brickman #874688 08/14/2012 1:08 PM
Much easier if you disconnect the hoist from the body, if possible from underneath. That means without raising the body.
Pull the pins from the lift arms and unbolt the hinges or torch off the bolts.
If you must remove the hoist w/ the body it is a little more work but unbolt if possible or torch off all the mounting plates to the truck frame, jack up the rear of the body carefully until you can get a beam under it at the rear. Place the ends of the beams on something very stable like oil drums and them move the the front and repeat the procedure. The beams can be something like oak 4x4's on your little body. once it's up drive or pull the truck away. DON'T forget to remove the hoses, driveshaft and linkage from the pump first!!
Be careful and don't do this alone as accidents do happen. (or are allowed to) It's not difficult if you think it through first.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
