5 members (2-Ton, 1955 1 Series, pdlightning, TooMany2count, Shade Baby), 154 guests, and 3 robots.
Topics128,079
Posts1,056,286
Members48,441
#799252 11/19/2011 10:30 PM
Trying to get 5.43 gears for this and the parts guy on the phone wants to know if it's Eaton or GM.
https://picasaweb.google.com/106959952217522043008/20111119
It is an Eaton. There are no aftermarket gears available for them. If it's from a 1 ton, it's a 5.13. 3/4 ton are mostly 4.56, though some did have 5.13s and there was a 4.10 option for the very late ('68-'72) version.
Bill Burmeister
It's a 1 1/2 ton.
It has 6.11 in it now.
I stand corrected. I still beleive it's an Eaton, though. There should be a stamped ID marking on the front face of the 3rd member, usually on the right side, though it could be on the top of the snout. Might be able to tell for sure with the codes.
Bill Burmeister
I'm sorry, but I can't find any markings on the castings.
ODSS Lawman
ODSS Lawman
The castings in a GM rear end will be located on the passenger side of the front of the differential where the driveshaft/torque tube goes into the rearend.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
Possibly says H1
Bill,
What makes you say it's an Eaton?
I've torn apart at least a half dozen of these rearends and I can confirm they are GM. I did the 5.43 upgrade to my COE a year or two back.
I don't know where the flange w/that seal in pics 2 and 4 came from. It shouldn't be from this rear end.
Jeff
My 1953 Chevrolet
1947.1 Gallery
Jeff where did you find the 5.43 ring and pinion?
I found it at a warehouse that dealt with NOS ring & pinions and drivetrain related parts. No more available unfortunately, I got one of the last sets. If I can find the interchange part numbers I'll post them.
Jeff
My 1953 Chevrolet
1947.1 Gallery
Oh yeah, as I'm sure you know, they are extremely rare for the open driveline 1 1/2 ton rear ends. The 1940 and older torque tube 1 1/2 ton trucks are still fairly rare, but more often available.
Jeff
My 1953 Chevrolet
1947.1 Gallery
OK I found a 5.14 out of a GMC. Will it fit?
Will a 1950 GMC 5.11 fit in my truck?
I replied to the other post of yours, and it occured to me, the 5.14 is out of a 1 ton rear end and will not fit. They did not make a 5.14 for 1 1/2 ton rear ends.
Jeff
My 1953 Chevrolet
1947.1 Gallery
Well I found the 5.43 and it's in. Onward and upward.
Sweet! cool
My 1953 Chevrolet
1947.1 Gallery
