7 members (Otto Skorzeny, UtahYork, Ponchogl, Lonnie, Bicounty, BC59, JW51),
160
Mod | | | Forums66 Topics128,089 Posts1,056,129 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Wade,
Can you post another picture or two of the heater unit?
| | | | | Joined: Feb 2012 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 50 | Yes im going to go pull it from the truck this afternoon. So i will have pictures up this evening.
52' Chevy 3100 5 window
| | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Boy, I sure like that control head. Separate setting for De-ice, and de-fog. Super cool! | | | | | Joined: Dec 2011 Posts: 402 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 402 | Don't know what kind it is...have rebuilt a standard, deluxe, and aftermarket box type and never seen one of these.
But it is COOL! Would love to see what you end up doing to it.
Jim | | | | | Joined: Feb 2012 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 50 | Here is a link the an album with 29 pictures of the heater and its parts. http://s138.photobucket.com/albums/q268/cotsi95/chevy%203100/Heater/ It definitely isn't factory, there were bolts holding the heaters itself on then 2 screws holding the part where the heater lines hook up to it and 2 holding the control panel on. I got it all off and took most of it apart. There are absolutely zero logos, part numbers or anything on the units except for where the water lines hook up. My question is exactly how does the heater get warm? I don't see any sort of heater core or a place where it would go. Also one thing that was really cool is it was wired up to the ignition switch and then in the control panel there is a cam lobe that depressed a switch on the backside to turn the motor on, very cool imo. It's definitely going back in the truck after I clean it up. But is anyone knows what it might be or where I can get some new knobs that'd be great since they are all broken now. Thanks, Wade
| | | | | Joined: Feb 2012 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 50 | Well after googling 1930-1950 heater I finally found what it is out of. It's out of a 1949-1951 chevy sedan!
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Where Does that heater draw air from? | | | | | Joined: Feb 2012 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 50 | Then engine bay I guess? Im still doing more research.
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | My question is exactly how does the heater get warm? Looking at Brads link It looks like your missing the heat exchanger. | | | | | Joined: Feb 2012 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 50 | Yep that's what it looks like. I found a factory air flow heater on craigslist for 100 for the entire setup so I will put just putting that in.
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Dads50, Wonderful tribute to your Dad. Bravo!! Harold
Harold Is a restoration ever finished? | | | | | Joined: Feb 2005 Posts: 36 New Guy | | New Guy Joined: Feb 2005 Posts: 36 | I have a similar heater setup I bought last weekend at a swap meet. There is a circular heater core inside on mine. | | |
