9 members (Otto Skorzeny, WICruiser, Peggy M, FAST55, Bucker, wilbur53, GMCJammer51, Forty9, 1 invisible),
63
Mod | | | Forums66 Topics128,159 Posts1,056,900 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 6 New Guy | | New Guy Joined: Apr 2005 Posts: 6 | 1950 3600, rear axle, inner and outer bearings. I'm thinking its impossible to get the original type barrel shaped roller bearings, and it'll have to be tapered rollers, which is ok, as long as they fit. I've tried FLAPS, only NAPA and Advance up here, with no luck. Jim Carter sent some chinese bearings that wouldn't fit over the end of the axle. I thought I'd found them at Truck Shop, and paid extra for "BCA original type bearings", but got made in Japan tapered rollers, but at least they fit. Any source I haven't seen out there? | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Have you tried going to your local Motion Industries/FAG/Timken dealer? If it is in the catalog they can get it.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Have a look at this posting and maybe you can find out from this member where he bought his bearings. rear bearing discussion | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | So long as you have the bearing number, give these guys a call. http://www.applied.com/Jeff | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | The Japanese bearings are probably quite good. Who makes them? MBS is one type that I've used in my '53 with great success. Those were original ball type.
Jeff | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | I'd be very happy with the Japanese bearings. Every one I've seen have been very high quality.
Kurt | | | | | Joined: Apr 2005 Posts: 6 New Guy | | New Guy Joined: Apr 2005 Posts: 6 | Thank You to everyone that responded, and to Brad for the Motion Industries suggestion, I had not heard of them. They don't know old trucks, but with bearing numbers their pretty good. Should have some one the way today, and the price was better than I found anywhere else. Thanks again, hope to be rolling soon. | | |
