1 members (UtahYork),
215
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,101 Posts1,056,181 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 256 'Bolter | | 'Bolter Joined: May 2012 Posts: 256 | As you all know I am in the process of restoring a 1930 Chevrolet Universal AD - Canopy Express, [ 1930 Chevrolet Universal AD - Canopy Express Truck Project ] when I acquired the Truck I got it in Pieces and Parts, mostly dissasembled. I have been doing research, reading on forums, etc. Have several books on hand and now getting underway on restoring. I have decided on doing a Driver Restoration, not planning on competing in any shows or trying to win any awards or accolades, just want to build a period close vehicle to enjoy and drive on occassion. Here is what I know, the engine has been rebuilt as well as the transmission. Most all of the Structural wood has been redone, a lot of the metal work has been done. My question is what is the best, easiest procedure of assembly from this point for doing a restoration ?? Considering I will be starting from a completetly dissamble vehicle. (As of Yesterday anyays) My first step was to Take Inventory of What I have, I laid out everything, and made a list of what I had on hand. Now I am trying to Develop a Plan of Action: How to attack this project and what to do when and the order. I am thinking that while it is completely apart, to clean up the frame, as it is in really great shape, a little surface rust here and there. Clean it up, throw on a fresh coat of paint, and then pull the wheels and check the bearings, brakes, suspension, and other components contained there in. Get a fully functioning rolling chassis. Then not sure after that, do I assemble & install, and set up the drivetrain, or start putting on the body back half, cab, up to the cowl. Then do the drive train, wiring, dash (gauges). Just trying to figure out the most logical and easierst method to do this from where I am now, with out having to take it back apart because i forgot something ( which is inevitable ), or take something off to put something in that should have been done first. Let me know how you guys have approached and attacked, this, or lessons you ahve learned from doing a restoration. 1929 Chevrolet AC International - 4 Door1930 Chevrolet AD Universal - Canopy Express TruckLove the Antique Chevrolet's from 1928-1932 The Beauty, Simplicity, History, and the Stories they Tell[/font] - - In the Stovebolt Gallery-- In the Gallery Forum | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | I think your process with starting at the frame and suspension is the right one. Personally if you have the coin to spend, move onto the drivetrain and build the body around the engine/tranny already installed. If I had one torn apart like that I figure it's easier to install the body around the drivetrain than to install the drivetrain with the body installed.
Anybody who tackles trucks from the 30's and before has my respect as so much changed from one year to the next.
Good luck!
Jeff | | | | | Joined: Jul 2012 Posts: 83 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 83 | I would definitly start with the frame. Do the frame, add the running gear and suspension, then add the body last. Thats how its done in the factory.
1953 1 ton panel
| | | | | Joined: Sep 2010 Posts: 1,707 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,707 | Frame, suspension, drive train, test drive,repair what doesn't work, body, wiring....all the while removing rust and painting parts as you go along. Don't forget to buy need parts before you need them. I took mine out for its maiden car cruise today. Still have more to do.  Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | All consistently good advice.
~Jim
| | | | | Joined: May 2012 Posts: 256 'Bolter | | 'Bolter Joined: May 2012 Posts: 256 | Wow, it seems that everyone has their own way of doing this... But that is good, gives me options !! YES, I got the truck in pieces, but I did a complete mock up of the body, check in my photos and you will see the body was pretty much completely assembled on the frame. Everything seems to fit nicely, sure there will be some work involved  That is what makes this even more fun it NOT knowing what went where, and not having any reference on HOW to put this thing together... Also the engine and tranny have already been rebuilt, and looks good from a general overview & inspection. Most all of the body work & repair has been done, just needs some touch up, sanding and then final painting. I spent this past weekend tearing down my mock up and yes I have plenty of pictures and sketches of what goes where, which hardware to use where, etc... I plan on spending the next month or so cleaning up (sanding, scrubbing, prepping) the frame for primer and paint. then I will get onto the suspension and brakes. Would like to beg a complete solid rolling chassis first. (Frame, Suspension, and Brakes) anything else I should do while on this Chassis/ Frame Mode ?!? I try to stay one step ahead, so that I am ordering parts, pieces, etc for the next phase while I am working on the current phase.
1929 Chevrolet AC International - 4 Door1930 Chevrolet AD Universal - Canopy Express TruckLove the Antique Chevrolet's from 1928-1932 The Beauty, Simplicity, History, and the Stories they Tell[/font] - - In the Stovebolt Gallery-- In the Gallery Forum | | | | | Joined: May 2012 Posts: 256 'Bolter | | 'Bolter Joined: May 2012 Posts: 256 | Well...
Been on vacation with the family, and will be home in a few days, once i return, (unpack, settle in, and get caught up on the home front) I will be back to work on the 1930. Plan is to cleam up and get a fresh coat of paint on the Chassis. In doing the chassis should I do the chassis then go back and take care of the brake components. I plan on painting the steel wheels eventually, but figure I would do that near the end of the restoration. Anything else I should consider or look at while in this phase ?!? 1929 Chevrolet AC International - 4 Door1930 Chevrolet AD Universal - Canopy Express TruckLove the Antique Chevrolet's from 1928-1932 The Beauty, Simplicity, History, and the Stories they Tell[/font] - - In the Stovebolt Gallery-- In the Gallery Forum | | | | | Joined: Aug 2012 Posts: 40 New Guy | | New Guy Joined: Aug 2012 Posts: 40 | even tho it's going to be a driver. I'd go above and beyond with the frame.... I'd hate to get it together and running and then get a stress crack in the frame...
as others have said I'd get the motor and tranny back in and double check all the mounts and reinforce if needed. Then move onto steering and breaks... it's a lot easier to run the hard lines with out the body, provided you are upgrading those...
After searching for a year I found the next project! 46' 1/2 ton in pieces! took 2 trips to get it home, but most of the hard work was already done!!! -jerry "Phil" the 46' | | | | | Joined: May 2012 Posts: 256 'Bolter | | 'Bolter Joined: May 2012 Posts: 256 | Well after reading and researching I am going to start on hte frame, clean it up, prime it and then paint. Going to start there. figure that is the Foundation of my 1930 and need a solid foundation in order to build the 1930.
Then I will work on suspension and brakes. Get a good clean functioning rolling chassis... 1929 Chevrolet AC International - 4 Door1930 Chevrolet AD Universal - Canopy Express TruckLove the Antique Chevrolet's from 1928-1932 The Beauty, Simplicity, History, and the Stories they Tell[/font] - - In the Stovebolt Gallery-- In the Gallery Forum | | | | | Joined: Aug 2012 Posts: 40 New Guy | | New Guy Joined: Aug 2012 Posts: 40 | Take lots of pics!!!! everything is better with pics!!!!
It's going to be one * of a process that takes time and money.... Cleaning up stuff is cheap while you save up for new items. Pick one area and focus on that... do keep the big picture in mind, but try not to get overwhelmed with it all. I'm at you're stage right now working on the frame and suspension... However, I get side tracked and start looking for things I wont need until waaaaaayyyyyyy later in the build.... Also set limits on how far you are willing to invest both time and money into specific things.... ie;engine, body work, paint, interior, ect... If it's not going to be a show truck you may not need to have that perfect cab and fenders? or dropping $2000 grand into the engine with shiny new stuff, when a fresh rebuild will do?
My plan so far is loosely like this... 1)frame and suspension 2)Engine, Tranny, brakes, Tires 3)Cab placement and rough fit. Doors and stuff 4)Engine bay 5)Bed, fuel system, electrical 6)rough interior, seats, console 7)fenders and exterior details 8)Odds and ends 9)disassemble and final prep for paint 10)paint 11)reassemble 12)finish interior 13)odds and ends 14) Drive it!!!!!
Estimated time to complete, 2 years with my work schedule... provided no major issues pop up!
After searching for a year I found the next project! 46' 1/2 ton in pieces! took 2 trips to get it home, but most of the hard work was already done!!! -jerry "Phil" the 46' | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Bearsfan,
Don't forget time for fieldtrips and socializing with other truck folks that will provide the extra hands when needed. The ODSS group is big on fieldtrips and socializing.
Hambone | | | | | Joined: May 2012 Posts: 256 'Bolter | | 'Bolter Joined: May 2012 Posts: 256 | Lugnutzz3000... I like your Plan of Action, very similar to what I am planning on doing with mine. Putting Tires of till the end, or close there abouts, so they do not dry rot sitting around on the truck or get damaged in the process. I am also going to ensure that it runs before i do a complete rough up of the body, fenders, bed, etc... so that i can easily access and fix/ correct any issues that may arise. I have set my goal to be 18 months ( LMAO ) sure that is not practical but hey... I will give myself Till end of 2014 to get it in test drive mode before tear down to finla paint  and as Hambone stated, socialization and field trips !! those are covered as well... in fact goingto do one this weekend. Been trying to find local bolters in the area to meet with, but no luck to date :/ 1929 Chevrolet AC International - 4 Door1930 Chevrolet AD Universal - Canopy Express TruckLove the Antique Chevrolet's from 1928-1932 The Beauty, Simplicity, History, and the Stories they Tell[/font] - - In the Stovebolt Gallery-- In the Gallery Forum | | | | | Joined: May 2012 Posts: 256 'Bolter | | 'Bolter Joined: May 2012 Posts: 256 | Ok, Spent the saturday working on the frame. Stripping it down and putting a coat of Primer on. About 1/5 Done. Taking my time and trying to do it right. First time I have ever attempted anything like this, so ... Also I am doing this with an angle grinder and wire brushes, as well as by hand in the hard to reach spots. Yes I am wearing PPE, Safety Goggles, Face Shield, Respirator and long sleeves & pants. Wires & paint flying everywhere !! Here are some Pictures from Saturday: Huckster: Frame Prime 01 Tomorrow hoping to get another section done. 1929 Chevrolet AC International - 4 Door1930 Chevrolet AD Universal - Canopy Express TruckLove the Antique Chevrolet's from 1928-1932 The Beauty, Simplicity, History, and the Stories they Tell[/font] - - In the Stovebolt Gallery-- In the Gallery Forum | | | | | Joined: May 2012 Posts: 256 'Bolter | | 'Bolter Joined: May 2012 Posts: 256 | Ok, was able to get back out and do some more work sunday on the frame getting another section done. Had to get more primer, and ended up destroying both Wire Brushes I had on hand, so back to the store for some more if i plan on getting naythign done tomorrow !! Here are some Pictures from Sunday: Huckster: Frame Prime 02 Tomorrow hoping to get another section done, Since I will be home hanging out with the kids :-) 1929 Chevrolet AC International - 4 Door1930 Chevrolet AD Universal - Canopy Express TruckLove the Antique Chevrolet's from 1928-1932 The Beauty, Simplicity, History, and the Stories they Tell[/font] - - In the Stovebolt Gallery-- In the Gallery Forum | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 |
~Jim
| | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | Putting Tires of till the end, or close there abouts, so they do not dry rot sitting around on the truck or get damaged in the process. We use a set of old tires and rims during the restore projects and replace them with new at the very end. Our attack plan usually goes like this: Frame Suspension engine/drive train brakes cab wiring interior doors front clip bed tires John
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: May 2012 Posts: 256 'Bolter | | 'Bolter Joined: May 2012 Posts: 256 | Thanks for the info... sounds like a good plan of attack Do have a curiosity Question for you, Why do you do the Driveline BEFORE doing the brakes ?? 1929 Chevrolet AC International - 4 Door1930 Chevrolet AD Universal - Canopy Express TruckLove the Antique Chevrolet's from 1928-1932 The Beauty, Simplicity, History, and the Stories they Tell[/font] - - In the Stovebolt Gallery-- In the Gallery Forum | | | | | Joined: May 2012 Posts: 256 'Bolter | | 'Bolter Joined: May 2012 Posts: 256 | Well another great day to grind, brush and prime !! spent another few hours outside on the frame, got another section done. This section was tedious, hand to hand work a lot of the areas. Also looks like that will be it for working on the frame for a few days, weather is back in the freezing zone. last 3 Days were sunny and in the 50's +, not suppose to get above freezing. Also have to get back to work tomorrow... Got to work to support my habit :p Here are some Pictures from Monday: Huckster: Frame Prime 03About 3/5 Done with the Frame itself... then >?< guess springs, cross memeber, axles, then onto the steering rods, or who knows... 1929 Chevrolet AC International - 4 Door1930 Chevrolet AD Universal - Canopy Express TruckLove the Antique Chevrolet's from 1928-1932 The Beauty, Simplicity, History, and the Stories they Tell[/font] - - In the Stovebolt Gallery-- In the Gallery Forum | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | Do have a curiosity Question for you, Why do you do the Driveline BEFORE doing the brakes ?? No real reason, it's just the way we do it. We could do the brakes first and then the drive train - but it's just not the way we did/do it. That's what's nice about this hobby. Everyone has their one specail way of doing somethings. And what's great about this site is everyone is willing to share their thoughts......
| | | | | Joined: May 2012 Posts: 256 'Bolter | | 'Bolter Joined: May 2012 Posts: 256 | OK, just wanted to make sure there was no learning reason behind the process. Did not know if you had learned from experience, always a method to the madness Thanks for the info... 1929 Chevrolet AC International - 4 Door1930 Chevrolet AD Universal - Canopy Express TruckLove the Antique Chevrolet's from 1928-1932 The Beauty, Simplicity, History, and the Stories they Tell[/font] - - In the Stovebolt Gallery-- In the Gallery Forum | | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | I have restored many 2 cyl. John Deere Tractors. This is my first attempt on a big truck (1957 GMC 370 LCF 2 1/4 Ton.) I am using close to the same procedure on it. When I bought it, it ran good, would work in all gears, BUT, NO BRAKES. I started by completely rebuilding the brakes, so I will be able to actually drive it to find any other major problems. Then: Decision time, do I sell it or restore it? If there seems to be no major problems with steering, engine, trans, rear end, Then tear down and begin the restoration.
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: May 2012 Posts: 256 'Bolter | | 'Bolter Joined: May 2012 Posts: 256 | Well continued onward & Forward, Identified some ofthe Clutch Assembly Components I have on hand... Working on Identifying which one is right, or if either is right :?: Huckster: Clutch Components 1929 Chevrolet AC International - 4 Door1930 Chevrolet AD Universal - Canopy Express TruckLove the Antique Chevrolet's from 1928-1932 The Beauty, Simplicity, History, and the Stories they Tell[/font] - - In the Stovebolt Gallery-- In the Gallery Forum | | | | | Joined: May 2012 Posts: 256 'Bolter | | 'Bolter Joined: May 2012 Posts: 256 | Love a Three day weekend  on top of that Monday was a beautiful afternoon, once the rain stopped and the sun came out, Temps hit the 70's !! So I rolled out the 30 and spent another few hours outside on the frame. Actually finished up the Frame section and got it all Primed !! Here are some Pictures from Monday: Huckster: Frame Prime 04 Today suppose to be back cool again, plus back to work for me...
1929 Chevrolet AC International - 4 Door1930 Chevrolet AD Universal - Canopy Express TruckLove the Antique Chevrolet's from 1928-1932 The Beauty, Simplicity, History, and the Stories they Tell[/font] - - In the Stovebolt Gallery-- In the Gallery Forum | | | | | Joined: Sep 2010 Posts: 1,707 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,707 | OOPS the photo link didn't work. Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: May 2012 Posts: 256 'Bolter | | 'Bolter Joined: May 2012 Posts: 256 | Thanks Wayne, think it is fixed now !! 1929 Chevrolet AC International - 4 Door1930 Chevrolet AD Universal - Canopy Express TruckLove the Antique Chevrolet's from 1928-1932 The Beauty, Simplicity, History, and the Stories they Tell[/font] - - In the Stovebolt Gallery-- In the Gallery Forum | | | | | Joined: Sep 2010 Posts: 1,707 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,707 | Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | |
