1 members (texczech), 51 guests, and 2 robots.
Topics128,024
Posts1,055,395
Members48,422
#86922 10/20/2004 1:19 AM
I just bought an original option radio for my '46. Obviously it is only AM and I am putting it in there only for looks. Here's my thought, tell me what you think. The radio it self appears it may be in good enough condition that it may actually work with a good cleaning. This would be option 1 but I have no idea how to go about cleaning it without causing damage and would likely never listen to it when driving. My other thought is to gut it with the exception of the front portion so looking at it it appears to be a stock radio. Then purchase a small/modern radio or even an XM radio (for the 50's & 60's channel) that has a wireless remote control and mount the unit inside the casing in the space the old radio parts once took up. It would even leave room to mount a modern single speaker in it. To access the radio the casing comes apart rather easily. I also thought about possibly making the front of the old radio hinged to "open up" revealing the new/modern radio. What do you think? Has anybody done this or seen it. I've seen radios hidding in the glove boxes but I don't like the idea of loosing the glove box. I really don't like the idea of mounting a modern radio under the dash for what I plan to keep looking as original as possible to the average non-stovebolt member.
I posted photos in my "details" photo album below if you want to see what radio I am talking about.
Tim Sheridan
1947 First Series Chevy 1/2-Ton
"Liberty Series" - "Art Deco" - Whatever you'd like to call it.
#86923 10/20/2004 2:02 AM
What does a 1946 radio look like? Is it a one piece radio?
I use wood alchohol and brushes and swabs to clean radios inside. I have an AD radio that I am restoring and it was filthy when I got it. It had been sitting in dirt with no back cover. It works quite well now and other than a missing back, which I have to fabricate, it is pretty well 100%.
There are people that will convert your radio to a new AM/FM while still using the original front. I really don't agree with that but the service is available.
1951 1 Ton Completed
#86924 10/20/2004 2:04 AM
I updated my photo album and added photos to the "details" photo album.
Tim
Tim Sheridan
#86925 10/20/2004 2:32 AM
Tim,
wow, what a great collection of photos. I will have to take more time to look at them all!
That radio looks like a good candidate for a restore. The front of it is amazing. If you want help testing it, send me an Email.
Fred
#86926 10/20/2004 4:20 AM
You can pick up a spray electronics cleaner that will clean any dirt within as well as clean the contacts. the back cover and the front can be removed very easy. the outside case can also be removed and wire brushed/ sanded if a little rough and painted silver and black where the speaker is. More than likely you will find that the paper capactors have since dried out and need replacing to get the radio back into operation. Make sure when you try to fire it up that you have it fused, quite often the capactor mounted on the bottom of the 0Z4 tube will short out once it warms up, this is a 1600 volt cap around .0068mf and a must replace before you try installing a new viberator, the solid state viberators do not like this one going bad..
#86927 10/20/2004 7:06 AM
If your only going to use it for looks then why
even care about the inside? Just just clean the
outside using whatever it takes including some
fine sandpaper and then use the proper rattle
can of paint.
#86928 10/21/2004 12:22 AM
I'm still debating the different options. I'm thinking I will try to clean it up and if I ruin it then I will go to option 2 and try putting a modern radio in it. I don't know much about electronics so I'll be learning as I go. I've got the basic wiring concepts down but transisters, resisters, etc....??? :confused:
Tim Sheridan
#86929 10/21/2004 5:45 AM
If you want to learn about electronics Radio Shack has some good introductory books.
1954 GMC De Luxe COE
#86930 10/21/2004 10:56 PM
I have an original radio and there is NO WAY I'm wasting time and resource to actually make it work. It's there for looks only.
Here is what I'm doing:
- install modern radio in glovebox (65$CDN)
- hook to voltage booster (6v>12v) (85$ CDN)
- download music on the ipod (350$CDN)
- connect ipod to tiny FM transmitter (45$CDN)
- pick up transmitter signal on the radio
Voila!
1953 Chevrolet 1300 - Daily driver
Collecting Vintage Whizzer motorbikes
http://www.whizzerick.com
#86931 10/22/2004 4:42 PM
That's a pretty cool radio. Where are you going to mount it? It looks pretty big and will take up alot of room. Does it hang under the dash or do you have to cut the dash to fit it in some where. Just curious there doesn't seem to be a lot of room under my dash.
I would use it for show only. Get a remote control radio put it behind/under the seat and you will be set. I'm using a Secret Audio radio in my 46. The control unit is going in the blank wiper plate on the passenger side and the rest is going behind the seat. The control unit is only 1.5" high and 4" wide so not much will be showing. Just some food for thought.
George
#86932 10/22/2004 10:12 PM
I must add to my previous comments about cleaning. On the AD radio, I discovered that alchohol actually melts the front bezel. So I wouldn't touch that nice frony plastic with it.
#86933 10/23/2004 4:11 AM
Quote
It's not as big as the photos make it look. From what I understand in the rare instances where these were in these trucks they were mounted below the headlight switch. This is also where I was planning to mounti my fog, hear and def switches. Those will now go on the other side of the sttering wheel.
I'm still debating in my own head if I should even wpend the time to try to get it to work or just use the caseing and front to house a modern radio.
Tim Sheridan
#86934 10/23/2004 4:44 PM
There is only about $6 of capactors in the radio that need replacing and can be replace in about an hour or so with a soldering gun. I find the tube radio as well has a different sound than the modern transistor radios of toda, much softer, and i seem to get more radio stations. The only problem is having the tubs checked, but checking around you should be able to find a TV shop that still has a tester, just make up a diagram of the tube locations (may already be one on the inside of the back cover) and check to make sure that there is still a readable number on the tube.
#86935 11/12/2004 6:21 AM
If you do decide to go the restoration route and find that you need a replacement tube or two, let me know. Along with my goofy old truck hobby, I have a goofy old tube amplifier hobby. Who knows, you might be able to get replacements locally, but I've got several crates of old tubes in the basement that I'd be happy to dig through for you.
Honda DOHC V-6 is to a Stovebolt
as a
Media-card MP3 player is to a Tube stereo
They both get the job done, but so much of the soul gets lost along the way.
Analog forever!
'52 3800 Panel
School bus conversion... Glass all around. (check the gallery!)
outside of a dog, a book is a man's best freind.
inside of a dog it's too dark to read.
-Groucho Marx
#86936 11/13/2004 6:04 PM
If anybody is interested in one of these radios I've seen three of them on e-bay in the last three days. None of them are mine by the way.
Item number: 4503960666
Item number: 4504067089
Item number: 4504066505
When it rains it pours...........
Tim Sheridan
#86937 11/13/2004 8:34 PM
tim, i just got my custom classic truck magazine and in there they in stalled all the switches inside the glove box in a 41 willys truck to clean up the dash looks slick. i have also seen the radio installed there. the truck won top 8 at the ridler show in chicago. i would bet it cost over 200,000 to do professionaly it took 6 1/2 years to do. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#86938 11/18/2004 1:06 AM
I plan to build a custom fiberglass glovebox and mount a modern DIN radio in it. I just picked up a new Kenwood unit for my BMW that plays CD's as well as MP-3 and WMA files burned on a CD-Rom, so you can stuff several hours of music in there. It cost less than $160. I love it, it makes 50W/ channel and sounds great. The unit has a full function remote control so you could control it with the glovebox shut if you provided a pathway for the IR sensor to run the remote. An alternate location would be under the seat or behind the dash on some sort of power up/down motorized mount so you could make it dissapear.
I plan to mount a pair of Blaupunkt 6" speakers in the front part of the headliner and a pair firing up from behind the seat. A small sub under the seat would create a pretty nice system. Just use dynamat to control the noise.
I don't mind things showing in the interior as long as metal wasn't sacrificed to do it.
Paint & Body Shop moderator
#86939 11/19/2004 3:36 PM
i just found a place to convert the radio without changing the look. go to s&m electro tech.com. they list prices and pictures of the finished product. not cheap. hope this helps. ron
2017 Buick Encore
See more pix
#86940 11/21/2004 4:55 AM
Junior Member
Junior Member
That is awesome.I would see if it worked before I gutted it,obviously it would be worth a lot more in working order,and the truck would be worth more with an original working radio.
You can mount a nice stereo under the dash and out of sight
49 Chevy 3600
67 GMC 3/4 ton
71 GMC 1/2,daily driver
http://www.sofnet.com/~eaglefeather/
When I die I want to die in my sleep,not screaming in terror like his passengers
