1 members (baldeagle),
79
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | The floor in my '51 half ton is completely rusted through and needs total replacement. Does a new aftermarket replacment floor extend beneath the seat or does it stop just short of it? The metal below my seat is fine.
Thanks.
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Jul 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 66 | I'm about to install new floorboards in the next few weeks. I bought mine fron Classic Parts (Counterpart brand). The new metal isn't really ready to go, unfortunately. The corner radii for the trans cover opening and the battery cover opening were too large. I had to fix all the corners so the covers would fit properly. You'll also need to salvage things from your old panels like gas pedal bracket, pedal felt seal retainer thingys and stuff like that. There are stiffening brackets on the originals, front to back, on each side of the trans cover opening (underneath). I had to fabricate new ones, I couldn't find them anywhere. To answer your question though, the ones that I bought extend just under the seat support flange. The only part of the seam that would be exposed is near each door opening. I'd be happy to email pictures of what I'm talking about if you PM me with your address. Dave Evans 52_3100 | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...and I like the ones that turn up and take up about 1/2 of the toeboard. I had to put them in my panel and what 52_300 is saying about the panels is correct. I had the same problems he did. I ended up adding a half inch in the middle of the floor panels. I got mine from The Truck Shop. | | | | | Joined: Jul 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 66 | I didn't know about the 1/2 inch in the middle. I haven't gotten to that point yet. That's a bunch of work. I think I'll add material to one side before I install them. Dave Evans 52_3100 | | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | Okay, I'm really puzzled as to why you have to add metal to the floors before installation! Aren't they supposed to fit darn near perfectly when you buy them new?? Can't the manufactures get it right? What's the problem here?
I'm no body man, and have never worked with sheet metal or the like. I thought this was going to be a straight forward job, but it looks like I was mistaken. Again.
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Jul 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 66 | I'm puzzled too at the fit problems of this junk. There's just no excuse for a lot of the problems, just carelessness by the manufacturer.
The replacement panels are nothing more than a good start. It takes a lot of work to really get them where you want them to be.
Dave Evans 52_3100
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I don't think it has to do with care, the panels are patterned from a single specific example [or sometimes from factory drawings], and may not be from your exact year - the pieces at the factory weren't always a good fit, so set aside for another - the misfits could have gone into the replacement parts stream and could even have been the "NOS" piece someone found to copy for a repro part be glad there's something available to start that's close  Bill | | | | | Joined: Jul 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 66 | Bill, I see your point. But it seems to me that if you buy floorboards, trans cover, battery hatch, and other parts all from the same vendor they should fit together. Dave | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Don't misunderstand me. I do NOT know if all have to have some added to it. I've never said I had to do that until I see someone else had to do the exact think. I figured with all the stuff I did I mis calulated somewhere along the line but going by all we had to go by we did have to add 1/2" in the middle or otherwise we'd had to add a piece on the side and I didn't want to do that. | | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | 52-3100, I sent you a PM regarding floor pics.
Thanks.
