0 members (), 130 guests, and 6 robots.
Topics128,077
Posts1,056,034
Members48,433
#864173 07/04/2012 4:10 AM
i have the straps but need a pic of the bracket that bolts to the body,im sure i could fab them if i had an idea where to start
55 -56 gmc panel truck
Sir Searchalot
Sir Searchalot
By straps, I hope you mean metal "straps". If you do mean metal straps, PM me your email address and I will send pics. The bracket should have been permanently attached to the "checks", as they are known. If you have cloth or strapping, that is someone's Rube Goldberg. See sheet 114 of the Assembly Manual. If you do not have the original type door checks, put an ad in "parts wanted", someone may have some.
here ya go - TF check arms
my arms dont look like that but they bolt to the top of the doors but it seems like theres something missing on the truck where i think they bolt on
At first glance they look like the ones on my 52 panel except where they attach to the door.
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/June172009001.jpg
yes, the 55-59 check arms are quite similar to the earlier years, with some difference in detail and size ..... need to post up a pic TJ, so we can figure what's been changed, missing, or damaged on yours - where they attach to the top of the doors there's just 2 threaded holes, where they attach to the header panel of the body is where the angle piece attaches to other holes, which can be seen here
Hey Bill, Are those check arms in your photo album available?
Larry
Larry Bear
55.5 Chevy 3100 Panel
probably not Larry, the pictured pair are on the blue panel now, and I have a panel in progress I need a pair for - but if I turn up spares I'll let you know, I might be able to find some
Thanks Bill!
Larry
Larry Bear
