1 members (Hotrod Lincoln),
97
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 24 New Guy | | New Guy Joined: Feb 2012 Posts: 24 | i have the straps but need a pic of the bracket that bolts to the body,im sure i could fab them if i had an idea where to start | | | | | Joined: Feb 2012 Posts: 24 New Guy | | New Guy Joined: Feb 2012 Posts: 24 | | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | By straps, I hope you mean metal "straps". If you do mean metal straps, PM me your email address and I will send pics. The bracket should have been permanently attached to the "checks", as they are known. If you have cloth or strapping, that is someone's Rube Goldberg. See sheet 114 of the Assembly Manual. If you do not have the original type door checks, put an ad in "parts wanted", someone may have some.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | here ya go - TF check armsBill | | | | | Joined: Feb 2012 Posts: 24 New Guy | | New Guy Joined: Feb 2012 Posts: 24 | my arms dont look like that but they bolt to the top of the doors but it seems like theres something missing on the truck where i think they bolt on | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | At first glance they look like the ones on my 52 panel except where they attach to the door. http://i140.photobucket.com/albums/r19/LutherParris/52Panel/June172009001.jpg
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, the 55-59 check arms are quite similar to the earlier years, with some difference in detail and size ..... need to post up a pic TJ, so we can figure what's been changed, missing, or damaged on yours - where they attach to the top of the doors there's just 2 threaded holes, where they attach to the header panel of the body is where the angle piece attaches to other holes, which can be seen hereBill | | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | Hey Bill, Are those check arms in your photo album available?
Larry | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | probably not Larry, the pictured pair are on the blue panel now, and I have a panel in progress I need a pair for - but if I turn up spares I'll let you know, I might be able to find some
Bill | | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | | | |
