8 members (mk72, Gdads51, ShopRag, TUTS 59, Hush, Otto Skorzeny, Hugh63c10, Hanks custodian),
149
Mod | | | Forums66 Topics128,043 Posts1,055,524 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2012 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2012 Posts: 59 | I tried looking at the vin number guides but I am honestly lost on how they work. I compared my Vin to the guide and I don't see any similarities my vin is BLCC646025.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Welcome to Stovebolt.com
The term VIN is often confused when used with any older vehicle.
Where did you find that code? It might be an engine serial number or a vehicle (body/cab) serial number.
Also, can you post a link to a photo of your vehicle? That would help us know the approximate year "ballpark".
The only code I can find with a BL in it is 1942 but your format is not right for that year.
You are asking this question in the right place - someone will help you figure this out.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy berts53, welcome, I am no expert on American serial numbers, but that looks like an engine number to me. I couldn't find BLCC, but I did find LCC as a prefix code to a 1953 216 from a truck, that sort of fits with your truck, hope that helps. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Its definitly an engine number, whoch was commonly used for titling vehicles before 1955. BLCC works out to be a Flint produced 1953 216 for a 3100 series truck.
Bill Burmeister | | | | | Joined: Jul 2012 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2012 Posts: 59 | you guys are correct, it is a 53 chevy truck. Oh ok. I just bought the truck and would like to get the orginal 6 working. | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Howdy berts53, you are on the right site for getting a six going again. Check out the Tech Tips section linked up top and The Engine Shop here in the forums to get started. Welcome to the 'Bolt. -W | | | | | Joined: Jul 2012 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2012 Posts: 59 | Found the engine number and am wondering if it is the original or not? The number on the engine is F0516A. I tried searching for a decode thread but was unsuccessful. Any help would be appreciated. Thanks in advance. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Definitly not the original engine. The code works out to be a '57-'62 235, built at Flint on May 16, and was originally installed in a Passenger car with manual trans.
Bill Burmeister | | | | | Joined: Jul 2012 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2012 Posts: 59 | I'm trying to get it running and would like to know if you know if it is a splash oil system or not? Do you rotate the slot where the distributor goes in and rotate it clock-wise in order to see if the oil pump works? Thanks, Bert | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | All 235s after '54 are full pressure oiling. You can test the oil pump by removing the distributor, then turning over the slotted oil pump drive using a drill and either an old distributor shaft or cutoff scredriver.
Bill Burmeister | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I'm trying to get it running and would like to know if you know if it is a splash oil system or not? Do you rotate the slot where the distributor goes in and rotate it clock-wise in order to see if the oil pump works? Thanks, Bert This should be discussed in the engine shop. Please don't hijack threads with new questions on a different topic. | | |
