4 members (Otto Skorzeny, KEVINSKI, k2handyman, Stovebolt48), 127 guests, and 2 robots.
Topics128,034
Posts1,055,552
#864689 07/06/2012 7:48 AM
I tried looking at the vin number guides but I am honestly lost on how they work. I compared my Vin to the guide and I don't see any similarities my vin is BLCC646025.
berts53 #864695 07/06/2012 12:12 PM
Welcome to Stovebolt.com
The term VIN is often confused when used with any older vehicle.
Where did you find that code? It might be an engine serial number or a vehicle (body/cab) serial number.
Also, can you post a link to a photo of your vehicle? That would help us know the approximate year "ballpark".
The only code I can find with a BL in it is 1942 but your format is not right for that year.
You are asking this question in the right place - someone will help you figure this out.
3B Offline
Hy berts53, welcome, I am no expert on American serial numbers, but that looks like an engine number to me. I couldn't find BLCC, but I did find LCC as a prefix code to a 1953 216 from a truck, that sort of fits with your truck, hope that helps.
3B #864765 07/06/2012 5:24 PM
Its definitly an engine number, whoch was commonly used for titling vehicles before 1955. BLCC works out to be a Flint produced 1953 216 for a 3100 series truck.
Bill Burmeister
you guys are correct, it is a 53 chevy truck. Oh ok. I just bought the truck and would like to get the orginal 6 working.
berts53 #865265 07/08/2012 5:04 PM
Socket Breaker
Socket Breaker
Howdy berts53, you are on the right site for getting a six going again.
Check out the Tech Tips section linked up top and The Engine Shop here in the forums to get started.
Welcome to the 'Bolt.
-W
Woogeroo #867852 07/19/2012 1:34 PM
Found the engine number and am wondering if it is the original or not? The number on the engine is F0516A. I tried searching for a decode thread but was unsuccessful. Any help would be appreciated. Thanks in advance.
berts53 #867854 07/19/2012 1:57 PM
Definitly not the original engine. The code works out to be a '57-'62 235, built at Flint on May 16, and was originally installed in a Passenger car with manual trans.
Bill Burmeister
LONGBOX55 #868217 07/20/2012 10:15 PM
I'm trying to get it running and would like to know if you know if it is a splash oil system or not? Do you rotate the slot where the distributor goes in and rotate it clock-wise in order to see if the oil pump works? Thanks, Bert
berts53 #868221 07/20/2012 10:34 PM
All 235s after '54 are full pressure oiling. You can test the oil pump by removing the distributor, then turning over the slotted oil pump drive using a drill and either an old distributor shaft or cutoff scredriver.
Bill Burmeister
berts53 #868227 07/20/2012 10:56 PM
This should be discussed in the engine shop. Please don't hijack threads with new questions on a different topic.
