2 members (k2handyman, TooMany2count), 66 guests, and 2 robots.
Topics128,030
Posts1,055,418
Members48,422
#868012 07/19/2012 11:12 PM
What oil do you guys use for the stock transmission and engines?
berts53 #868018 07/19/2012 11:39 PM
I use Rotella"T" in my trucks and add ZDDP as well at the recomendation of my engine builder.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike B #868029 07/20/2012 1:17 AM
what about the transmission?
berts53 #868048 07/20/2012 7:12 AM
you should use what ever you feel comfortable with, as you are going to get answers from each ends of the spectrum, and everything in the middle.
Every type of oil you can imagine, someone swears by it, with one consistent factor, they all run. So as long as it is formulated for engine, or transmission use, it should be fine.
brokenhead #868084 07/20/2012 11:20 AM
Just use off the shelf oils unless you have some special build.
Builder #868091 07/20/2012 11:52 AM
Its not something special. I just thought with such an older trany, the oil would be thicker or something that people don't normally use.
